Joined: 10/3/2021(UTC) Posts: 61  Location: Wichita Falls, TX Thanks: 6 times Was thanked: 3 time(s) in 3 post(s)
Can we get 8 overlay layers? There are MANY times I have graphics on screen that I want to keep on screen but add another and could use more then 4. Anyone else?
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: cody@raceontexas.com  Can we get 8 overlay layers? There are MANY times I have graphics on screen that I want to keep on screen but add another and could use more then 4. Anyone else? Overlays support layers. That's the general advice when this comes up.
 1 user thanked WaltG12 for this useful post.
I need them to be independent. I dont want to have to stack layers to do it. Would be much easier to just have 8 vs the 4 now.
While that may be true, the key to getting feature requests taken seriously is to explain your usecase (which you really haven't done) and explain why existing options just don't cut it, which you really haven't done.
And when I say "that's the standard advice given", I mean I've seen Martin give that advice making this same request.
And I highly doubt anything you've said so far in this thread would change that, especially with last year's increase in Mix inputs giving you the ability to have independent control and gradual transitions in and out for all 10 layers of a transparent input.
And, of course, the upcoming 27 gives you more options for controlling the positioning of Mix inputs (or anything else) on those 10 layers if the overlays you want to add need PiP rather than being set for full screen.
If that's not good enough for your usecase, which it may not be, you're going to want to provide a lot more detail (or, well, any detail) as to why.
Joined: 1/23/2022(UTC) Posts: 132  Location: Milton Keynes Thanks: 14 times Was thanked: 14 time(s) in 14 post(s)
Originally Posted by: WaltG12  especially with last year's increase in Mix inputs giving you the ability to have independent control and gradual transitions in and out for all 10 layers How do you achieve transitioning in of layers, please?
Joined: 2/23/2019(UTC) Posts: 138  Thanks: 19 times Was thanked: 29 time(s) in 26 post(s)
Originally Posted by: spinfold  How do you achieve transitioning in of layers, please? If you need more than 4 overlays add a blank input that you show as one of the overlays, then add say 5 Mix inputs and configure these as layers on the blank input. On the Mix inputs you can transition in any input and that will show as independently animated overlays.
Originally Posted by: RichDanby  Originally Posted by: spinfold  How do you achieve transitioning in of layers, please? If you need more than 4 overlays add a blank input that you show as one of the overlays, then add say 5 Mix inputs and configure these as layers on the blank input. On the Mix inputs you can transition in any input and that will show as independently animated overlays. I will try this. Best option so far. It would be way to hard to explain in detail what I need.
Originally Posted by: RichDanby  Originally Posted by: spinfold  How do you achieve transitioning in of layers, please? If you need more than 4 overlays add a blank input that you show as one of the overlays, then add say 5 Mix inputs and configure these as layers on the blank input. On the Mix inputs you can transition in any input and that will show as independently animated overlays. Ah, OK. I'm using all 15 mixes in my show already!
