Joined: 7/4/2015(UTC) Posts: 65   Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Does anyone have issues updating when the program says there is one ?Seems to hang up and give errors send off the reports but still gives issues All though sometimes it will just go through...I then often sometimes see update on the bottom and it is already
Joined: 8/2/2013(UTC) Posts: 1,109   Location: Fairhope, Alabama USA Thanks: 603 times Was thanked: 204 time(s) in 170 post(s)
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
wtmuradiotv wrote:Does anyone have issues updating when the program says there is one ?Seems to hang up and give errors send off the reports but still gives issues All though sometimes it will just go through...I then often sometimes see update on the bottom and it is already In my experience the most likely cause of this is another program running in the background that vMix needs to be closed to install correctly. If you want to try the internal update again, runs task manager and shut anything running in the background and see if the install works ok.
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
Untill now not had any problems updating via vMix...
If you keep having problems, do what sinc747 suggested: download newest version from vMix website.
