Amnon
#1 Posted : Saturday, October 5, 2019 3:31:48 AM(UTC)
Amnon
Hi everyone.
I noticed lately that every now and then I have to click an input a couple of times for vMix to switch to it. I thought the wireless mouse was at fault so I got a wired mouse, but the same happened. I then figured out the reason it happens. Unless the cursor was at a stand still on the shot, it would not switch. I figured I will get a Stream Deck and that will solve the problem. Watched Tim's video and read the forums, and it seems everyone who talks about using the Streamdeck is talking about setting up a profile from scratch. So my question is, is it possible to use a current profile and control it with the Streamdeck?
Amnon
#2 Posted : Saturday, October 5, 2019 8:04:43 AM(UTC)
You can reprogram/change any streamdeck profile to your heart's content
Amnon on 10/5/2019(UTC)
Amnon
#3 Posted : Saturday, October 5, 2019 8:52:36 AM(UTC)
Amnon
Sorry, I should have been more clear. Can a vMix profile be modified so it is controlled by the streamdeck. I have around 40 different vMix profiles for the different shows I do.
Amnon
#4 Posted : Saturday, October 5, 2019 9:12:39 AM(UTC)
Don't see why you would have to modify your vMix profile, its a controller that you can link to your existing shortcuts or even send API calls with
it's a fancy (but very useful) little additional keyboard ;-)
Just as you have multiple vMix profiles the streamdeck can have multiple profiles so you can match with them each others in functionality. Works straight out of the box (after you told a key what to do)
While there are additional apps for it to work with it there really isn't any need for those. you wont regret getting one or more
thanks 2 users thanked doggy for this useful post.
Amnon on 10/15/2019(UTC), RobLambert on 1/22/2020(UTC)
RingsideReport
#5 Posted : Thursday, October 10, 2019 5:42:42 AM(UTC)
RingsideReport
Canada
I have multiple vMix productions programmed into a Stream Deck XL with triggers too.
I have a startup on the XL with has each production as a button on the Stream Deck. Each button is programmed with a MultiAction (Stream Deck function). For this to work the Stream Deck software has to be running before pressing a button.
The multi-action contains two commands:
1) Open vMix production file (those with a .vmix extension)
2) Switch Stream Deck My Stream Deck Config[/img]profile to the profile that I programmed and saved with the production loaded
Each profile has a button programmed to return to the default profile which has all the production buttons.
So when I press a button to load a production, vMix loads with all the production presets and the Stream Deck buttons have the config of that production, including the triggers.
[img=https://ringsidereport.net/wp-content/uploads/2019/10/streamdeck-config.jpg]
In a few weeks, I will build a tutorial on how I did this and share it on YouTube.
thanks 2 users thanked RingsideReport for this useful post.
Amnon
#6 Posted : Wednesday, October 16, 2019 1:45:42 AM(UTC)
Amnon
Got the 15 button stream Deck, upgraded to vMix 22, read a few posts with instructions, and the only thing I managed to do is to have a button that switches between preview and program. I must be over thinking this :-)
I'll wait for your tutorial.
Amnon
#7 Posted : Wednesday, October 16, 2019 2:09:11 AM(UTC)
Amnon
Or you use the elgato integration option (see below) or you create http request or link to shortcuts strait into the streamdeck (website or hotkey options)
Say you dragged the website option to a button and tell it to "http://127.0.0.1:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=demo" it will ad the word demo to the first textblock of a title in input 1
or drag a hotkey option and give it the keycombination you prepared in vMix itself (vMix window has to be the active one to respond then)
https://www.vmix.com/knowledgebase/article.aspx/180/using-the-elgato-stream-deck-with-vmix
Amnon on 10/17/2019(UTC), RobLambert on 1/16/2020(UTC)
Manjinder
#8 Posted : Friday, October 9, 2020 8:52:42 PM(UTC)
Manjinder
India
Hi All
Request All To Guide me a string to enable the following on Stream Deck.
Title/XAML on Overlay 1.
I have assigned the Button but on Active Input only not able to write the string for any Overlay.
MJ
Manjinder
#9 Posted : Friday, October 9, 2020 9:12:21 PM(UTC)
Manjinder
India
Hi All
Can someone help with a string for Elgato Stream to change the camera view in Virtual set.
\MJ
vmixgreg
#10 Posted : Saturday, October 10, 2020 1:20:30 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Hi Manjinder,
The Shortcut to use is:
"SelectIndex"
Where the Value = 1,2,3 or 4 depending on which preset Zoom thumbnail you want to switch to.
vMixGreg
Manjinder
#11 Posted : Saturday, October 10, 2020 4:31:08 PM(UTC)
Manjinder
India
Hi Greg
Thanks.
Was not able to activate.
Let say I want to trigger Zoom Thumbnail 1 on Input layer 19. Im Trying with the followinbg.
Function=ActiveInput&SelectIndex=1
Is this Ok.
Mj
Manjinder
#12 Posted : Saturday, October 10, 2020 10:46:11 PM(UTC)
Manjinder
India
Hi Greg
Stream Deck doesn't work as per its shown in Vmix videos or Am i making some mistakes.
MJ
#13 Posted : Saturday, October 10, 2020 10:48:15 PM(UTC)
@ Manjinder
How are you setting up your Shortcuts on the Stream Desk?
https://www.vmix.com/kno...to-stream-deck-with-vmix
Manjinder
#14 Posted : Saturday, October 10, 2020 10:55:06 PM(UTC)
Manjinder
India
Thanks Ice
Tried all options shown in this video but Vmix doesn't detect the Stream Deck.
Thanks MJ
Similar Topics
Elgato Stream Deck + XL Feature Request (Feature Requests)
by jermanprod 6/18/2026 4:02:02 AM(UTC)
Elgato Stream Deck Plus (General Discussion)
by hajandr 1/6/2026 4:32:43 AM(UTC)
Elgato Stream Deck XL (Hardware Compatibility)
by Turnier 2/9/2024 5:35:28 AM(UTC)
Elgato Stream Deck how is controlled (Hardware Compatibility)
by fabfab10 10/9/2021 6:37:42 PM(UTC)
Elgato Stream Deck Toggle Request (Feature Requests)
by Rome 6/14/2021 7:41:00 AM(UTC)
Elgato Stream Deck Visibility in vMix 22 - Now you see it, now you don't - Stream Deck keys not show (Hardware Compatibility)
by Kimon 4/10/2020 8:23:23 PM(UTC)
elgato stream deck mobile (General Discussion)
by miaviel 3/27/2020 10:13:53 AM(UTC)
Exclamation Mark on Elgato Stream Deck XL (3rd Party Software and Development)
by rnhturner 3/12/2020 1:18:36 PM(UTC)
VMix and Elgato Stream Deck (Hardware Compatibility)
by Sven 12/28/2019 11:52:14 PM(UTC)
Elgato Stream Deck XL... (General Discussion)
Belarus desmar 5/27/2019 11:44:35 PM(UTC)
Bitofocus Companion support (for more flexible use of the Elgato Stream Deck) (Feature Requests)
by richardgatarski 4/15/2019 8:28:57 PM(UTC)
Elgato Stream Deck Visibility in vMix 22 - Now you see it, now you don't (Hardware Compatibility)
by rjmurdock 2/3/2019 12:32:37 AM(UTC)
Elgato Stream Deck SDK now Available (Hardware Compatibility)
by imagebotique 1/9/2019 11:51:01 PM(UTC)
Elgato Stream Deck profile, tweaked for vMix and IRP (General Discussion)
by Ario 11/28/2018 7:24:00 AM(UTC)
Elgato Stream Deck support through Companion (Hardware Compatibility)
by Anders 10/22/2018 5:59:01 AM(UTC)
Elgato Stream Deck support (Feature Requests)
by kozaka 3/25/2018 7:40:10 AM(UTC)
Elgato Stream Deck and vMix (Hardware Compatibility)
by r5dad 2/21/2018 4:53:18 PM(UTC)
