I use the Stream Deck XL and Vmix with the current version. In VMIX I have created keyboard shortcuts that I would like to access with the Stream Deck. It works very well on one PC and on the second PC the inputs coming from the stream deck are ignored by VMIX. The input arrives at the command prompt without any errors. Where do I have to look so that it also works on the 2nd PC? I don't want to go through the "Activators" setting. Who can help me?
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
I assume you created your shortcuts with Streamdeck key detection. You should know that if you change PC or even if you reinstall the Streamdeck, the key code is changed, so you must reassign all the shortcuts. I don't know if this has been fixed in the latest versions of the Streamdeck software. Otherwise the solution is to go through Bitfocus Companion. I don't use it because I put GIF images on my Streamdeck keys.
