I downloaded the excellent app from elgato: stream deck mobile
When I try to create a software shortcut when I click a button "find", I click the button on the app on the phone that I want to make a shortcut.
The vmix software cannot detect the button from the app.
Does anyone have any idea why it doesn't work? Do you know if the software supports the application at all?
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Dont believe the vMix Stream Deck Plugin is even capable of detecting this "virtual" Stream Deck.
will have to work the standard way ie , like before the plugin existed in the hardware version, by setting your commands in the streamdeck ( HW or app)
Stream Deck works very well even without the vmix plugin by using the "website" button option and giving it an API call function
(Not going to register to try the app ;-) )
how i create API call function?
And is there anyone here who can still give me an answer about the app?
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Have you installed the Stream Deck software on the vMix computer? And have you installed the vMix actions in this software? There is a nice tutorial from Tim, and basically you will probably (haven't tried it) have to follow all the steps he does with the hardware version, and additionally connect your app to the software:
Originally Posted by: dmwkr  Have you installed the Stream Deck software on the vMix computer? And have you installed the vMix actions in this software? There is a nice tutorial from Tim, and basically you will probably (haven't tried it) have to follow all the steps he does with the hardware version, and additionally connect your app to the software: Yes I did and it didn't work
