Joined: 9/20/2011(UTC) Posts: 22  Location: Raleigh, NC Thanks: 44 times Was thanked: 3 time(s) in 3 post(s)
Hi everyone. I noticed lately that every now and then I have to click an input a couple of times for vMix to switch to it. I thought the wireless mouse was at fault so I got a wired mouse, but the same happened. I then figured out the reason it happens. Unless the cursor was at a stand still on the shot, it would not switch. I figured I will get a Stream Deck and that will solve the problem. Watched Tim's video and read the forums, and it seems everyone who talks about using the Streamdeck is talking about setting up a profile from scratch. So my question is, is it possible to use a current profile and control it with the Streamdeck?
Thanks Amnon
Joined: 12/27/2012(UTC) Views messages in topic : 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
You can reprogram/change any streamdeck profile to your heart's content
Sorry, I should have been more clear. Can a vMix profile be modified so it is controlled by the streamdeck. I have around 40 different vMix profiles for the different shows I do. Amnon
Don't see why you would have to modify your vMix profile, its a controller that you can link to your existing shortcuts or even send API calls with it's a fancy (but very useful) little additional keyboard ;-) Just as you have multiple vMix profiles the streamdeck can have multiple profiles so you can match with them each others in functionality. Works straight out of the box (after you told a key what to do) While there are additional apps for it to work with it there really isn't any need for those. you wont regret getting one or more
 2 users thanked doggy for this useful post.
Joined: 6/17/2019(UTC) Posts: 9   Location: Montreal, Quebec Thanks: 33 times Was thanked: 2 time(s) in 1 post(s)
I have multiple vMix productions programmed into a Stream Deck XL with triggers too.
I have a startup on the XL with has each production as a button on the Stream Deck. Each button is programmed with a MultiAction (Stream Deck function). For this to work the Stream Deck software has to be running before pressing a button.
The multi-action contains two commands:
1) Open vMix production file (those with a .vmix extension) 2) Switch Stream Deck My Stream Deck Config[/img]profile to the profile that I programmed and saved with the production loaded
Each profile has a button programmed to return to the default profile which has all the production buttons.
So when I press a button to load a production, vMix loads with all the production presets and the Stream Deck buttons have the config of that production, including the triggers.
[img=https://ringsidereport.net/wp-content/uploads/2019/10/streamdeck-config.jpg]
In a few weeks, I will build a tutorial on how I did this and share it on YouTube.
 2 users thanked RingsideReport for this useful post.
Got the 15 button stream Deck, upgraded to vMix 22, read a few posts with instructions, and the only thing I managed to do is to have a button that switches between preview and program. I must be over thinking this :-) I'll wait for your tutorial. Amnon
Originally Posted by: Amnon  Got the 15 button stream Deck, upgraded to vMix 22, read a few posts with instructions, and the only thing I managed to do is to have a button that switches between preview and program. I must be over thinking this :-) I'll wait for your tutorial. Amnon Or you use the elgato integration option (see below) or you create http request or link to shortcuts strait into the streamdeck (website or hotkey options) Say you dragged the website option to a button and tell it to "http://127.0.0.1:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=demo" it will ad the word demo to the first textblock of a title in input 1 or drag a hotkey option and give it the keycombination you prepared in vMix itself (vMix window has to be the active one to respond then) https://www.vmix.com/knowledgebase/article.aspx/180/using-the-elgato-stream-deck-with-vmix&
Hi All
Request All To Guide me a string to enable the following on Stream Deck.
Title/XAML on Overlay 1.
I have assigned the Button but on Active Input only not able to write the string for any Overlay.
Thanks MJ
Hi All
Can someone help with a string for Elgato Stream to change the camera view in Virtual set.
Thanks \MJ
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 65 Location: Canada
Thanks: 1 times Was thanked: 20 time(s) in 19 post(s)
Hi Manjinder,
The Shortcut to use is: "SelectIndex" Where the Value = 1,2,3 or 4 depending on which preset Zoom thumbnail you want to switch to.
vMixGreg
Hi Greg
Thanks.
Was not able to activate.
Let say I want to trigger Zoom Thumbnail 1 on Input layer 19. Im Trying with the followinbg.
Function=ActiveInput&SelectIndex=1
Is this Ok.
Thanks Mj
Hi Greg
Stream Deck doesn't work as per its shown in Vmix videos or Am i making some mistakes.
Thanks MJ
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Thanks Ice
Tried all options shown in this video but Vmix doesn't detect the Stream Deck.
Thanks MJ
