Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
Hi ! I'm trying to get Behringer UMC404HD to wwork with VMix but after installing ASIO driver I get this error https://www.dropbox.com/...6-30%2017.38.30.png?dl=0-Tommi UPDATE! There was also another driver which needed to be installed (Windows Driver + UMC driver)
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Does this give you 4 individual channels in VMIX?
I just picked up one of these units.
Are you powering it off USB or wall outlet?
I am having trouble using the headphone out to monitor with it. Not sure I have the correct driver.
Joined: 2/19/2017(UTC) Posts: 31   Location: United States Thanks: 23 times Was thanked: 2 time(s) in 1 post(s)
I just ordered one of these today, so I look forward to learning along with you on how to maximize the use of this with VMix.
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
So I just got the 404HD myself. It took me 10 min to figure out why I couldn't see all the channels. When you select an audio device you need to use the "UMC ASIO Driver" option. Then you can choose what line you want to show up from the 4 available (or it has combo lines 1 & 2, 3 & 4).
 2 users thanked jvphobic for this useful post.
has anyone encounter a problem where you still have audio levels in vMix even with your audio knob down in the umc404hd ??
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: MrFahrenheit360  has anyone encounter a problem where you still have audio levels in vMix even with your audio knob down in the umc404hd ?? What kind of source have you connected, and how? I don't have one, but afaik this could happen if you connect a line level source via XLR. XLR plug activates mic level on some interfaces.
2 XLR inputs from a mixer, in 1 and 2. If they are playing music or talking, in vMix I will hear audio and see levels even if I turn down the Gain knobs on the umc404hd interface.
Try connecting with a 1/4" TRS jack plug. This should activate the line level input on the interface.
Thanks: 4 times Was thanked: 20 time(s) in 19 post(s)
Originally Posted by: MrFahrenheit360  2 XLR inputs from a mixer, in 1 and 2. If they are playing music or talking, in vMix I will hear audio and see levels even if I turn down the Gain knobs on the umc404hd interface. if you are taking a signal off a mixer it is already a line level source.. the XLR inputs and gain controls on the audio interface are primarily used for microphones.. if you want to lower the signal as it comes into the interface you either need to lower it via the mixer or you could buy attenuators that can reduce 10, 20 or 40db off the signal.. also using TRS connections is probably a better idea for signal coming off a mixer..
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
according to the manual, the TRS input has a 20db attenuation
