-TA_
#1 Posted : Saturday, July 1, 2017 10:44:34 AM(UTC)
-TA_
Hi !
I'm trying to get Behringer UMC404HD to wwork with VMix but after installing ASIO driver I get this error
https://www.dropbox.com/...6-30%2017.38.30.png?dl=0
-Tommi
UPDATE!
There was also another driver which needed to be installed (Windows Driver + UMC driver)
BluestemVideo
#2 Posted : Saturday, July 8, 2017 11:35:23 AM(UTC)
BluestemVideo
Does this give you 4 individual channels in VMIX?
#3 Posted : Saturday, July 8, 2017 11:40:49 AM(UTC)
yes
BluestemVideo
#4 Posted : Thursday, July 13, 2017 12:14:12 PM(UTC)
BluestemVideo
I just picked up one of these units.
Are you powering it off USB or wall outlet?
I am having trouble using the headphone out to monitor with it. Not sure I have the correct driver.
Bamboo
#5 Posted : Friday, July 14, 2017 11:44:51 PM(UTC)
Bamboo
I just ordered one of these today, so I look forward to learning along with you on how to maximize the use of this with VMix.
jvphobic
#6 Posted : Thursday, August 3, 2017 8:15:01 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
So I just got the 404HD myself. It took me 10 min to figure out why I couldn't see all the channels. When you select an audio device you need to use the "UMC ASIO Driver" option. Then you can choose what line you want to show up from the 4 available (or it has combo lines 1 & 2, 3 & 4).
thanks 2 users thanked jvphobic for this useful post.
Bamboo on 7/23/2018(UTC), RingsideReport on 8/9/2019(UTC)
MrFahrenheit360
#7 Posted : Tuesday, September 22, 2020 7:07:10 AM(UTC)
MrFahrenheit360
has anyone encounter a problem where you still have audio levels in vMix even with your audio knob down in the umc404hd ??
dmwkr
#8 Posted : Thursday, September 24, 2020 7:38:05 AM(UTC)
dmwkr
What kind of source have you connected, and how? I don't have one, but afaik this could happen if you connect a line level source via XLR. XLR plug activates mic level on some interfaces.
MrFahrenheit360
#9 Posted : Thursday, September 24, 2020 8:06:43 AM(UTC)
MrFahrenheit360
2 XLR inputs from a mixer, in 1 and 2. If they are playing music or talking, in vMix I will hear audio and see levels even if I turn down the Gain knobs on the umc404hd interface.
dmwkr
#10 Posted : Thursday, September 24, 2020 3:29:55 PM(UTC)
dmwkr
Try connecting with a 1/4" TRS jack plug. This should activate the line level input on the interface.
mtone
#11 Posted : Thursday, September 24, 2020 4:00:00 PM(UTC)
mtone
if you are taking a signal off a mixer it is already a line level source.. the XLR inputs and gain controls on the audio interface are primarily used for microphones.. if you want to lower the signal as it comes into the interface you either need to lower it via the mixer or you could buy attenuators that can reduce 10, 20 or 40db off the signal..
also using TRS connections is probably a better idea for signal coming off a mixer..
Peter1000
#12 Posted : Thursday, September 24, 2020 7:28:26 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
according to the manual, the TRS input has a 20db attenuation
Similar Topics
vMix & Behringer UMC404hd delay thoughts (General Discussion)
by neato23 4/22/2024 12:37:35 AM(UTC)
Multiple Audio interfaces - UMC1820 - UMC404HD (Hardware Compatibility)
by adrider 12/5/2023 8:54:49 PM(UTC)
Behringer UMC404HD only mono Output (Hardware Compatibility)
by fenki86 11/5/2022 4:05:22 PM(UTC)
Audio Output to Behringer UMC404HD (General Discussion)
by mgrayeb 4/11/2021 1:17:05 AM(UTC)
UMC404HD Dropouts only in vMix (Hardware Compatibility)
by MarkNF82 3/6/2021 9:14:10 AM(UTC)
Has anyone managed to use the UMC404HD without dropouts? (Hardware Compatibility)
by Vince Beck 12/16/2020 3:32:05 AM(UTC)
Audio output to UMC404HD issue while vMix is running (General Discussion)
by Mike_in_tX 6/18/2017 3:39:34 PM(UTC)
