farsh
#1 Posted : Monday, January 13, 2014 5:15:42 PM(UTC)
farsh
I am using a laptop with realtek hi def audio as the only audio device.
using vmix the recording setup and selecting WMV streaming , so my output is streamed to the home network port 8080.
I like to be able to preview one source on the laptop speakers / headphone jack before clicking on fade that sends it out.
but looks like this is not possible with only one audio device . when I do this on the laptop I hear both output and input . and if I deselect the audio , it cuts it off the streaming output .
please advise.
thanks.
TVIason
#2 Posted : Tuesday, January 14, 2014 2:43:36 AM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Currently there is not such feature like wirecast has. You can't pre listen to any input. It would be very handy if you could. I suggest you post a topic in the feature request section with this option, cause I'm not sure Martin looks here.
Iason
Similar Topics
Audio output from AJA IO X3 is sped up when used with Vmix (General Discussion)
by ejpontius 5/18/2026 7:01:25 AM(UTC)
The ability for Preset Bundles to also save overlay and audio output settings (Feature Requests)
by kuuminsh 2/11/2026 11:10:19 PM(UTC)
Vmix audio output to windows (General Discussion)
by sackboydad 12/8/2025 2:14:02 AM(UTC)
No Audio output with VCable sometimes (General Discussion)
by Geffers 5/17/2025 7:42:35 PM(UTC)
No audio output if not audio source playing (Systems)
by canal10 2/25/2025 3:58:39 AM(UTC)
NDI Multistream audio output? (NDI)
by neato23 11/23/2024 2:14:33 AM(UTC)
Multi Channel Audio Output (General Discussion)
by anshul 8/27/2024 2:18:19 PM(UTC)
Clearing Audio Outputs (General Discussion)
by Korbinian.Werner 7/24/2024 12:01:52 AM(UTC)
Kona 4 analog audio output while using capture sped up (General Discussion)
by billpoore 2/13/2024 3:12:37 AM(UTC)
No Audio Output Capture? (General Discussion)
by Hazza 8/30/2023 2:17:56 PM(UTC)
NDI Audio output sample rate different from vMix master sample rate (NDI)
by Maestro232 8/7/2023 1:07:39 AM(UTC)
Audio output bus just not working (General Discussion)
by mdtechprod 2/8/2023 7:29:44 PM(UTC)
More Audio Outputs / Groups instead of Busses (Feature Requests)
by cookdoeyl 12/3/2022 3:46:46 AM(UTC)
Test Tone Button to Test Audio Outputs (Feature Requests)
by nestor 11/17/2022 8:50:30 AM(UTC)
MORE Audio Output Channels PLEASE (Feature Requests)
by LeeL 10/20/2022 12:23:46 AM(UTC)
Live-Streaming Audio Output (General Discussion)
by commerz81 8/21/2022 4:18:16 AM(UTC)
Please help - Audio "duplication" issue: I now hear both vMix audio AND any Windows audio output (General Discussion)
by Ragnvald 8/14/2022 7:47:44 AM(UTC)
.mp3 audio output (Feature Requests)
by JonBell 5/25/2022 3:55:02 AM(UTC)
How to monitor master audio output? (General Discussion)
by DThompson55 4/25/2022 6:13:09 AM(UTC)
8 channel (4 X Stereo) audio output selectable (Feature Requests)
by Kristoph 2/21/2022 9:42:32 PM(UTC)
Dell PC distorted audio output to Decklink Duo 2 (Hardware Compatibility)
by ibwalkn 1/27/2022 5:25:38 AM(UTC)
Audio Output to Behringer UMC404HD (General Discussion)
by mgrayeb 4/11/2021 1:17:05 AM(UTC)
Direct audio output from input? (General Discussion)
by TBacker 3/25/2021 10:30:23 AM(UTC)
AUDIO OUTPUT BUS A set to HDMI but doesn't work (General Discussion)
by Jeffry_Ghost 3/3/2021 8:18:40 PM(UTC)
Aja Io 4k Plus Audio Output question (Hardware Compatibility)
by Burnmaester 1/21/2021 5:16:57 AM(UTC)
Featuure request: vMix Call direct audio output (Feature Requests)
by SRH4T3 12/12/2020 7:11:43 PM(UTC)
How do Audio Outputs work? Need to send custom mix out (General Discussion)
by SeanEmer 10/18/2020 6:47:32 AM(UTC)
UMC ASIO hardware Audio output not working for bus (Hardware Compatibility)
by russoandrew 10/1/2020 12:27:38 AM(UTC)
Using Pi to stream all audio output from my pc to my stereo (General Discussion)
by escotispz 8/24/2020 4:02:24 PM(UTC)
Decklink Duo 2 Embedded Audio Output (Hardware Compatibility)
by ARSP 8/19/2020 10:57:04 AM(UTC)
