Jeffry_Ghost
#1 Posted : Wednesday, March 3, 2021 8:18:40 PM(UTC)
Jeffry_Ghost
Czech Republic
Hello guys
I have a little problem with audio outputs via HDMI. I am kind of guy who like to do all by myself. But I've been struggling with this almost months (sometimes it work sometimes don't {I tested it on 4 different PC})
I need multiple audio outputs for our show and one of it need to be via HDMI for preview monitor for clients. But when I go to settings I always find multiple choices for HDMI even though I have only one HDMI pluged and one DVI (just monitor for work with vMix)
on the pictures below you can see multiple HDMI options and I tried all of them one by one but none of them works (all drivers are actual, even tried with newly installed PC)
audio outputs2.png (129kb) downloaded 7 time(s).
audio outputs1.png (115kb) downloaded 1 time(s).
But when I set it to Default Windows Playback Device it works, but it's not comfortable for me, because I need to use default playback for windows on realtek because of monitoring landing page etc.
audio outputs3.png (129kb) downloaded 0 time(s).
If anybody got some ideas or solutions I would be greatful
thanks 1 user thanked Jeffry_Ghost for this useful post.
vvcvvc on 3/7/2021(UTC)
#2 Posted : Sunday, March 7, 2021 6:32:47 PM(UTC)
If you want to use the BMD outputs for this monitor, you must configure the EXTERNAL renderer output !
But I'd rather plug this monitor to the Nvidia HDMI and select the 2nd Nvidia HDMI out for this audio bus.
Jeffry_Ghost
#3 Posted : Friday, March 19, 2021 10:18:52 PM(UTC)
Jeffry_Ghost
Czech Republic
That's the funny thing, the HDMI is pluged into NVIDIA graphic card.
When i tried the external render it worked of course.
I found one solution but it's not that comfortable for me. Everytime even if I didn't unpluged the hdmi I need to go to windows audio settings and rename the HDMI output to whatever and then it works until I shut down my pc then I need to rename it again eventho it's all can be seen in vMix audio output options.
This work at least on PC, when I try the same steps on laptop then it's not working
montyfabio
#4 Posted : Saturday, February 25, 2023 11:50:55 PM(UTC)
montyfabio
Italy
i've solved in the same way
in my case i have a graphic card nvidia 3060 with 4 output ports.. first 2 are always ok.. port 3 and 4 always have no audio and i solve with the rename trick
