AUDIO OUTPUT BUS A set to HDMI but doesn't work
Joined: 9/9/2017(UTC) Posts: 36  Location: Jeffry_Ghost Thanks: 10 times Was thanked: 2 time(s) in 2 post(s)
Hello guys I have a little problem with audio outputs via HDMI. I am kind of guy who like to do all by myself. But I've been struggling with this almost months (sometimes it work sometimes don't {I tested it on 4 different PC}) I need multiple audio outputs for our show and one of it need to be via HDMI for preview monitor for clients. But when I go to settings I always find multiple choices for HDMI even though I have only one HDMI pluged and one DVI (just monitor for work with vMix) on the pictures below you can see multiple HDMI options and I tried all of them one by one but none of them works (all drivers are actual, even tried with newly installed PC)  audio outputs2.png (129kb) downloaded 7 time(s). audio outputs1.png (115kb) downloaded 1 time(s).But when I set it to Default Windows Playback Device it works, but it's not comfortable for me, because I need to use default playback for windows on realtek because of monitoring landing page etc.  audio outputs3.png (129kb) downloaded 0 time(s).If anybody got some ideas or solutions I would be greatful
 1 user thanked Jeffry_Ghost for this useful post.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
If you want to use the BMD outputs for this monitor, you must configure the EXTERNAL renderer output !
But I'd rather plug this monitor to the Nvidia HDMI and select the 2nd Nvidia HDMI out for this audio bus.
That's the funny thing, the HDMI is pluged into NVIDIA graphic card.
When i tried the external render it worked of course.
I found one solution but it's not that comfortable for me. Everytime even if I didn't unpluged the hdmi I need to go to windows audio settings and rename the HDMI output to whatever and then it works until I shut down my pc then I need to rename it again eventho it's all can be seen in vMix audio output options.
This work at least on PC, when I try the same steps on laptop then it's not working
Joined: 10/31/2022(UTC) Posts: 14   Location: Camerino Was thanked: 3 time(s) in 2 post(s)
Originally Posted by: Jeffry_Ghost  That's the funny thing, the HDMI is pluged into NVIDIA graphic card.
This work at least on PC, when I try the same steps on laptop then it's not working i've solved in the same way in my case i have a graphic card nvidia 3060 with 4 output ports.. first 2 are always ok.. port 3 and 4 always have no audio and i solve with the rename trick
