How to monitor master audio output?
Joined: 9/30/2020(UTC) Posts: 54  Location: Manchester Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
I desperately want a LUFS meter so I can see what I'm sending to the streaming service. The only way I see to do that is to add a LUFS meter VST on the master while keeping its fader at 100%, and then use its gain to make what should be volume adjustments to the streaming service. That's because gain is pre VST, while the fader is post VST. Am I missing something or is this the correct approach? There's not a separate audio monitor channel strip you could wire this to like you might see in a DAW, correct?
