DThompson55
#1 Posted : Monday, April 25, 2022 6:13:09 AM(UTC)
DThompson55
I desperately want a LUFS meter so I can see what I'm sending to the streaming service. The only way I see to do that is to add a LUFS meter VST on the master while keeping its fader at 100%, and then use its gain to make what should be volume adjustments to the streaming service. That's because gain is pre VST, while the fader is post VST. Am I missing something or is this the correct approach? There's not a separate audio monitor channel strip you could wire this to like you might see in a DAW, correct?
