Noveliste
#1 Posted : Tuesday, December 17, 2019 4:39:36 PM(UTC)
Noveliste
Whenever I put up a powerpoint slideshow, it takes of at rapid speed. I've tried setting duration in powerpoint, tried slide show settings in vMix. The only thing that has worked is making 10 or so copies of the first slide, so I can put it up and pause it before it takes off. But if I want to go away and come back to some place in the middle of the show, it takes off again. It's really frustrating.
ask
#2 Posted : Tuesday, December 17, 2019 5:25:15 PM(UTC)
ask
Open the Slide Show Settings. Set the duration to "0". Using a Powerpoint Presenter, setup shortcuts using "NextItem" and "PreviousItem"
Noveliste on 12/18/2019(UTC)
Noveliste
#3 Posted : Wednesday, December 18, 2019 2:43:46 AM(UTC)
Noveliste
So you're using display capture rather than loading the PPT into vMix?
ask
#4 Posted : Wednesday, December 18, 2019 5:56:35 AM(UTC)
ask
No. You do all this in vMix. https://www.vmix.com/hel...m?SlideShowSettings.html
Noveliste
#5 Posted : Wednesday, December 18, 2019 11:32:05 AM(UTC)
Noveliste
I don't want to use a presenter for various reasons. So I put the shortcuts on the keyboard. But it still takes off. And it moves forward on its own. Really frustrating.
Noveliste
#6 Posted : Wednesday, December 18, 2019 5:43:08 PM(UTC)
Noveliste
I tried a presenter. Same problem. As soon as I invoke powerpoint, it takes off. And it continues automatically advancing, no matter what I do. Invoking the PreviousItem shortcut may work for a second or two, but then it takes off again.
ask
#7 Posted : Thursday, December 19, 2019 6:24:50 AM(UTC)
ask
Noveliste
#8 Posted : Thursday, December 19, 2019 6:36:29 AM(UTC)
Noveliste
Also done. Same problem.
Noveliste
#9 Posted : Thursday, December 19, 2019 7:00:30 AM(UTC)
Noveliste
IF I simply put PPT on screen, no problem. However, as part of multi-view, it advances uncontrollably. Multiview has camera input (me) in front; background image in the background, and PPT slides in between.
#10 Posted : Thursday, December 19, 2019 7:10:10 AM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
what if you have a virtual input of your PTT input and put that in your multiview ?
Noveliste
#11 Posted : Thursday, December 19, 2019 7:22:03 AM(UTC)
Noveliste
Same result.
davidelsbury
#12 Posted : Thursday, December 19, 2019 12:02:14 PM(UTC)
davidelsbury
I have had this issue too. My fix is to not use PPT files, which is a huge pain.
ask
#13 Posted : Thursday, December 19, 2019 1:48:51 PM(UTC)
ask
OK This is not what you originally reported. However, the solution is the same.
Try this.
Open a new blank profile.
Open a Powerpoint input
Open Slide show settings and set to "0" Close and save settings. (Click the top right "x" button on the settings window)
Create a shortcut using "NextItem" to advance the slides. Set the source as Preview.
Open a Camera Input
Open a blank input.
Open the Settings page. Select Multiview and choose a side by side template. Select the Camera as Overlay 1 and PPoint as Overlay 2.
Put the Blank input into Program and the PPoint into Preview.
Open the shortcut panel and test....
Alternatively point the shortcut directly at you PPoint input. I use up to 15 different PPoint presentations so find it easier to do the above.
I also UNTICK Automatically Mix Audio, Restart on Transition and Play with Transition
Noveliste
#14 Posted : Friday, December 20, 2019 3:01:51 AM(UTC)
Noveliste
Excellent! Thank you! Solves this problem, and streamlines some other things I was doing. Thanks for the info, and for your patience!
Similar Topics
Powerpoint x talking head -> 3 separate multicorder files (General Discussion)
by sdspieg 9/22/2025 2:08:19 PM(UTC)
Vnix Preset PowerPoint slides (General Discussion)
by neuegs 9/16/2025 6:41:56 AM(UTC)
Vmix call + Powerpoint (vMix Call)
by adambou 6/29/2023 11:30:27 PM(UTC)
Specific Powerpoint Slide in Playlist (General Discussion)
by DougF 2/8/2023 6:58:51 AM(UTC)
Powerpoint pptx Files not Loading (General Discussion)
by Podcast Bob 7/20/2022 2:38:03 AM(UTC)
PowerPoint file Not Loading (General Discussion)
by sojorner 5/11/2022 1:56:38 AM(UTC)
How do I gain the highest resolution from desktop capture when using Chrome and Powerpoint? (General Discussion)
by Ken Robinson 3/30/2022 8:24:11 PM(UTC)
How to gain the highest resolution from desktop capture when using Chrome and Powerpoint (NDI)
by Ken Robinson 3/30/2022 5:56:23 PM(UTC)
PowerPoint as an input in Layers (General Discussion)
by Ville 2/10/2022 3:34:36 AM(UTC)
PowerPoint import (Feature Requests)
by Chris Daum 1/26/2022 6:29:09 PM(UTC)
PowerPoint looping (General Discussion)
by JohnG 11/20/2021 8:59:47 AM(UTC)
NDI Output for PowerPoint (NDI)
by boris9831 11/16/2021 5:59:15 AM(UTC)
PowerPoint Slides Through EasyWorship (NDI)
by Southwood Church 10/9/2021 6:05:23 AM(UTC)
vMix and PowerPoint (General Discussion)
by DaveCS 7/6/2021 2:18:11 PM(UTC)
Quick reload of Powerpoint (Feature Requests)
by clibil 4/29/2021 5:34:18 AM(UTC)
Auto-update of PowerPoint slides (General Discussion)
by coskel22 4/20/2021 1:05:27 AM(UTC)
PowerPoint Integration - Permanent display of slide X of Y (Feature Requests)
by camdenyoung 4/9/2021 9:55:28 AM(UTC)
Manipulating PowerPoint via triggers (General Discussion)
by MZBC 1/30/2021 11:16:13 PM(UTC)
PowerPoint Slides... (General Discussion)
by Alba 12/13/2020 1:24:53 AM(UTC)
Best way to include PowerPoint (General Discussion)
by MichaelOlsen 10/31/2020 4:34:14 PM(UTC)
PowerPoint with audio (General Discussion)
by Trilback 10/30/2020 5:49:35 PM(UTC)
PowerPoint Slides not updating with NDI (NDI)
by thom0422 10/29/2020 10:29:52 PM(UTC)
Powerpoint Template (General Discussion)
by PastorG 10/1/2020 4:12:32 AM(UTC)
Streamdeck with PowerPoint on a networked machine (Hardware Compatibility)
by alibabakes5 8/4/2020 3:45:39 AM(UTC)
Video/Audio From Powerpoint in vMix? (General Discussion)
by greggibson 6/5/2020 12:56:51 AM(UTC)
Sending shortcuts over NDI to PowerPoint? (General Discussion)
by white_production 5/30/2020 7:24:34 PM(UTC)
Powerpoint - Variable slide times (Feature Requests)
by Hylkewolf 4/20/2020 10:00:16 PM(UTC)
Powerpoint & Audio (General Discussion)
by sjmcmc 4/16/2020 10:24:57 AM(UTC)
Powerpoint input - Change slide timing (General Discussion)
by Hylkewolf 4/16/2020 1:02:12 AM(UTC)
Remote Presenter control of Powerpoint deck? (General Discussion)
by pdxjoe 3/9/2020 9:48:53 AM(UTC)
