neuegs
#1 Posted : Tuesday, September 16, 2025 6:41:56 AM(UTC)
neuegs
I have a 30 second music clip that every Sunday the PowerPoint slide is different. The slide is layered onto the music clip. Sometimes it loads, most of the time it shows up offline. I have a folder in My Documents called Church Cal Sunday where the PowerPoint slide files are stored. I prepare the services weeks in advance and save each week as a separate preset. I'm unable to determine if the Preset is looking at the correct path to fetch the slide.
