Vnix Preset PowerPoint slides
Joined: 8/29/2020(UTC) Posts: 7   Location: Arizona Thanks: 1 times
I have a 30 second music clip that every Sunday the PowerPoint slide is different. The slide is layered onto the music clip. Sometimes it loads, most of the time it shows up offline. I have a folder in My Documents called Church Cal Sunday where the PowerPoint slide files are stored. I prepare the services weeks in advance and save each week as a separate preset. I'm unable to determine if the Preset is looking at the correct path to fetch the slide.
