Manipulating PowerPoint via triggers
I want to setup a PowerPoint input with manual play. When I transition into the input, it will show the current slide. What I want to do is setup a trigger to advance to the next slide on transition out. Is that possible and if so, how and will it automatically move to the first slide as the next slide when it gets to the end of the presentation? Thanks!
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Yes it's possible
The best way to do this is to check the manual where all commands are listed and explained for use with triggers.
