Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
When one positions an object it can get rather tricky getting the exact positon where you want it. Could up and down arrows be added to get the correct position one wanted? Attached is an example of the idea.  vmix.jpg (336kb) downloaded 1 time(s).
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
try this:
when you hover your mouse over one of these sliders use your mouse's scroll-wheel to fine tune
You can also use the cursor on the object you want to move to press the left mouse button and move the object to the desired position.
Tried, just clicked on the center arrows (the one I wanted to move) and yeap using the arrow keys on the keyboard did the trick, perfect. Thanks.
Or after clicking on one of the sliders use the arrow keys
much easier than trying to hit those small arrows with the cursor ;-)
Edit , see you found it at the time i was writing this
Joined: 11/21/2014(UTC) Posts: 12 Location: New Zealand
