bigjohn767
#1 Posted : Wednesday, May 9, 2018 10:25:39 AM(UTC)
bigjohn767
Hi, We just started using vMix and have had great success so far with the video both recording and live feed. However, I am having problems with the audio. It records great but I can't get it to output to the live feed. I have one HDMI monitor as the production monitor and then a second HDMI feed to a TV and projector. I can play Youtube videos outside of vMix with no problem. Can someone tell me what settings to check in vMix to allow the audio to output with the live feed?
Thanks!!!
#2 Posted : Wednesday, May 9, 2018 10:50:20 AM(UTC)
Been discussed many times already, did you search the forum before posting?
Point is to set Master audio to the HDMI out in Windows settings
Guillaume
Similar Topics
Vmix audio output to windows (General Discussion)
by sackboydad 12/8/2025 2:14:02 AM(UTC)
No Audio output with VCable sometimes (General Discussion)
by Geffers 5/17/2025 7:42:35 PM(UTC)
No audio output if not audio source playing (Systems)
by canal10 2/25/2025 3:58:39 AM(UTC)
NDI Multistream audio output? (NDI)
by neato23 11/23/2024 2:14:33 AM(UTC)
Multi Channel Audio Output (General Discussion)
by anshul 8/27/2024 2:18:19 PM(UTC)
Clearing Audio Outputs (General Discussion)
by Korbinian.Werner 7/24/2024 12:01:52 AM(UTC)
Kona 4 analog audio output while using capture sped up (General Discussion)
by billpoore 2/13/2024 3:12:37 AM(UTC)
No Audio Output Capture? (General Discussion)
by Hazza 8/30/2023 2:17:56 PM(UTC)
NDI Audio output sample rate different from vMix master sample rate (NDI)
by Maestro232 8/7/2023 1:07:39 AM(UTC)
Audio output bus just not working (General Discussion)
by mdtechprod 2/8/2023 7:29:44 PM(UTC)
More Audio Outputs / Groups instead of Busses (Feature Requests)
by cookdoeyl 12/3/2022 3:46:46 AM(UTC)
Test Tone Button to Test Audio Outputs (Feature Requests)
by nestor 11/17/2022 8:50:30 AM(UTC)
MORE Audio Output Channels PLEASE (Feature Requests)
by LeeL 10/20/2022 12:23:46 AM(UTC)
Live-Streaming Audio Output (General Discussion)
by commerz81 8/21/2022 4:18:16 AM(UTC)
Please help - Audio "duplication" issue: I now hear both vMix audio AND any Windows audio output (General Discussion)
by Ragnvald 8/14/2022 7:47:44 AM(UTC)
.mp3 audio output (Feature Requests)
by JonBell 5/25/2022 3:55:02 AM(UTC)
How to monitor master audio output? (General Discussion)
by DThompson55 4/25/2022 6:13:09 AM(UTC)
8 channel (4 X Stereo) audio output selectable (Feature Requests)
by Kristoph 2/21/2022 9:42:32 PM(UTC)
Dell PC distorted audio output to Decklink Duo 2 (Hardware Compatibility)
by ibwalkn 1/27/2022 5:25:38 AM(UTC)
Audio Output to Behringer UMC404HD (General Discussion)
by mgrayeb 4/11/2021 1:17:05 AM(UTC)
Direct audio output from input? (General Discussion)
by TBacker 3/25/2021 10:30:23 AM(UTC)
AUDIO OUTPUT BUS A set to HDMI but doesn't work (General Discussion)
by Jeffry_Ghost 3/3/2021 8:18:40 PM(UTC)
Aja Io 4k Plus Audio Output question (Hardware Compatibility)
by Burnmaester 1/21/2021 5:16:57 AM(UTC)
Featuure request: vMix Call direct audio output (Feature Requests)
by SRH4T3 12/12/2020 7:11:43 PM(UTC)
How do Audio Outputs work? Need to send custom mix out (General Discussion)
by SeanEmer 10/18/2020 6:47:32 AM(UTC)
UMC ASIO hardware Audio output not working for bus (Hardware Compatibility)
by russoandrew 10/1/2020 12:27:38 AM(UTC)
Using Pi to stream all audio output from my pc to my stereo (General Discussion)
by escotispz 8/24/2020 4:02:24 PM(UTC)
Decklink Duo 2 Embedded Audio Output (Hardware Compatibility)
by ARSP 8/19/2020 10:57:04 AM(UTC)
Dante Audio Output by Source (Feature Requests)
by adamjohns 8/9/2020 11:38:54 PM(UTC)
Direct Audio outputs of individual inputs (Feature Requests)
by dperaltajr 7/18/2020 4:39:12 AM(UTC)
