doyousee.me
#1 Posted : Thursday, June 6, 2013 3:01:28 PM(UTC)
doyousee.me
Hi
sorry to slowly running for the record of asking stupid questions, but i'm getting more and more into this mixer and have ideas and plans like there's no tomorrow :)
I'm experimenting with rtsp as a remote input using my local on-lan stream server as a source (i stream rtmp from fmle into it and connect vmix to it)
if i use the rtsp connector, i get an ever increasing delay, unless i tick the low latency box, but then the image goes to poor quality.
if i use the rtmp connector, there is a delay, which is constant and is ver usable (not really nice, i have to delay my other camera's to make the image work) but i can't record replays on rtmp, or set the sound.
are there settings i could use to improve the incoming rtsp (i have tried, but to no avail), or is this just known behavior and fixed in v10 which i can't wait to get my hands on (although my year of free updates has probly passed so i have to reach into the backpocket)
oh by the way in vlc the stream has a solid delay, so it's there, but constant.
M@ik
davesuemcbride
#2 Posted : Friday, June 7, 2013 2:18:35 AM(UTC)
davesuemcbride
Was just logging in to ask same / similar question, and here this was right on top ;)
I'm also using the RTSP input, I see < 1 second delay at input startup, but after 15 minutes or so it's grown to 30 or more seconds. Tried both with and without 'low latency mode' option, and buffer is set to 300ms. Stream is pulled from a Cube 220, 1080p @ 30 @ 10mb/sec, hardwired with only a Gigabit switch (was trying to see how it'd all work 'maxed out' - very nice BTW but for the delay).
Running vMix x64 9.1.0.31 on Win 7, i7 quad (laptop), 8 GB. Running way too much stuff at once - probably should have tried vMix solo on a fresh boot but increasing delay isn't quite what I'd expect anyway from maxing out the machine. CPU running about 15% average, with 1.5 GB free memory. Network utilization right about what I'd expect at 10mb/sec.
On similar subject, any realistic guidelines on how far one can go on the mixing rig? Assuming external encoding (just HDMI output), are 4 or 5 simultaneous live 1080p30 inputs plausible, perhaps along with one or two Flash overlays and a few videos 'in waiting'?
Plans and ideas - tell me about it - job suffers due to obsession, family moves out, lack of sleep causing delusions of being some sort of broadcast producer... (sad music in background).
Thanks,
David McBride
#3 Posted : Friday, June 7, 2013 7:17:12 AM(UTC)
Was thanked: 4665 time(s) in 1607 post(s)
Hi Guys,
Could you please try the following small update:
http://www.vmix.com.au/download/vmix9.exe (9.1.0.34)
In particular it fixes an issue with how vMix deals with certain bitrates from the Cube.
(And maybe other RTSP sources as well, but the additional devices support is not being added until vMix 10)
Also, as a note to anyone who has any issues with the Teradek Cube devices, feel free to
email us at info@vmix.com.au for a fast response as the Cube is an officially supported device.
doyousee.me
#4 Posted : Friday, June 7, 2013 1:24:39 PM(UTC)
doyousee.me
that seems to do at least some trick.. (i have been running for an hour now but it's still about a second delay , which is to be expected in my current setup, yesterdays test would have been tens of seconds by now)
the 'lowlatency' switch still makes the image quality unusable.
M@ik
davesuemcbride
#5 Posted : Saturday, June 8, 2013 2:44:16 AM(UTC)
davesuemcbride
Martin you rock!
The update looks to have solved my issue (the Cube) - ran it for about 10 minutes and no perceptable change in delay - subsecond throughout.
I'll run a longer test this weekend, and also compare results with the two low latency settings.
One bonus - I had noticed a slight 'stutter' before, perhaps in sync with the key frames - that's gone now as well.
Thanks again,
David McBride
Similar Topics
vMix can not decode video on VLC(RTMP, UDP, RTSP,RTP) stream (General Discussion)
by truonghtv 5/31/2025 7:41:51 PM(UTC)
Detect whether rtsp is inputting via a script (General Discussion)
by mrsfalcon 2/12/2025 2:03:22 AM(UTC)
HEVC RTSP INPUT (General Discussion)
by gre2gor 12/25/2024 6:30:19 PM(UTC)
RTSP input streams suddenly corrupted (General Discussion)
by MP1958 12/16/2024 4:15:52 AM(UTC)
vMix VLC Stream RTSP flag options (General Discussion)
by rv15 7/29/2024 3:33:13 PM(UTC)
RTSP / RTMP CPU load in vMix? (General Discussion)
by dontpanic 3/15/2024 7:15:06 PM(UTC)
RTSP VIA Ethernet for JVC PTZ KY-PZ100BU (General Discussion)
by tborland1 3/12/2024 5:49:29 AM(UTC)
Trying to disconnect a VLC RTSP source according to the hour of day (General Discussion)
by xlamano 7/20/2023 8:01:52 PM(UTC)
Possible to take RTSP camera with Blue Iris and convert to port forward to H.264 of MJPEG? (General Discussion)
by jileki 12/26/2022 2:13:58 AM(UTC)
RTSP vs NDI for sources (General Discussion)
by mjgraves 11/1/2022 12:44:00 AM(UTC)
PTZO wont come into vMix via RTSP/UDP - but will for VLC...and works fine in OBS (General Discussion)
by cmdevivo 3/3/2021 8:16:54 AM(UTC)
RTSP IP Camera Input Image loss (General Discussion)
by robocox 2/20/2021 1:22:46 AM(UTC)
Automatic switching of RTSP cameras (General Discussion)
by gorbunov.oa 2/9/2021 9:41:10 PM(UTC)
rtsp stream input has gone away (General Discussion)
by peterg60 8/29/2020 7:01:25 AM(UTC)
Budget priced PTZ rtsp camera (Hardware Compatibility)
by Gene Naber 8/2/2020 5:23:02 AM(UTC)
RTSP - Why is this so unstable? (General Discussion)
by rjwerth 6/9/2020 1:29:22 AM(UTC)
IP Camera gives video via RTSP and audio via VLC? (Hardware Compatibility)
by StryderTV 5/15/2020 8:19:30 PM(UTC)
Dynamic usage of RTSP or RTMP streams (General Discussion)
by gre2gor 4/28/2020 2:05:43 PM(UTC)
RTSP/MJPEG Live Stream output (Feature Requests)
by tal041482 4/14/2020 5:11:34 AM(UTC)
How do I bring a Panasonic AW-UE70 PTZ cam into vMix with rtsp? (Hardware Compatibility)
by Victory Radio 3/31/2020 12:01:40 AM(UTC)
RTSP Stream Login Problem (General Discussion)
by manuel.vita96 1/10/2020 11:28:48 PM(UTC)
RTSP streams not recording (Instant Replay)
by mark 11/20/2019 8:13:31 PM(UTC)
Vmix 22: video jumps when adding second rtsp source? Worse with powerful egpu (General Discussion)
by noonsong 9/13/2019 5:12:35 PM(UTC)
support for rtsp h265 (General Discussion)
by pagu 6/6/2019 1:22:11 AM(UTC)
RTSP & Audio issue (General Discussion)
by SFX Group 5/17/2019 4:57:14 PM(UTC)
how to add and hear audio from rtsp flux camera (General Discussion)
by pagu 4/18/2019 6:38:12 PM(UTC)
IP camera - RTSP Stream setup don't work ? (General Discussion)
by Rob75 1/28/2019 10:33:22 PM(UTC)
input rtsp black screen after minuts (General Discussion)
by pagu 8/2/2018 3:57:22 AM(UTC)
NDI and RTSP Apps (NDI)
by FAndreas 5/5/2018 5:46:21 AM(UTC)
Replay with RTSP input streams (Instant Replay)
by tovi 4/26/2018 7:56:15 AM(UTC)
