xlamano
#1 Posted : Thursday, July 20, 2023 8:01:52 PM(UTC)
xlamano
Spain
I want to disconnect a STREAM/SRT type source, in its VLC mode (RTMP, UDT, RTP, RTSP, TS) connected to an RTSP source according to the time of day
The conflict is that I have an IP camera connected by 4g, and a limitation of monthly output data
So I would like to script the behavior of the vMix to disconnect from the camera's RTSP stream overnight
The source cannot be stopped or paused, I thought about closing the input, but using a script I don't see the way to add an input of these characteristics (I only see an option to add inputs of the type, video, image, title... in short , sources associated with a file, but not more complex sources with more arguments like an RTSP)
https://www.vmix.com/hel...utFunctionReference.html
Any ideas?
Thank you so much
nikosman88
#2 Posted : Friday, July 21, 2023 12:36:17 AM(UTC)
nikosman88
Greece
Any ideas?
Thank you so much
Hello. Your vmix is running 24/7?
xlamano
#3 Posted : Friday, July 21, 2023 1:59:20 AM(UTC)
xlamano
Spain
Any ideas?
Thank you so much
Yes, it is a totally unattended 24-hour broadcast that would show an animation at times when the cameras would not work. The rest of the time I have programmed a loop of cameras (3 in total) so that they change from one to the other
nikosman88
#4 Posted : Friday, July 21, 2023 4:26:14 AM(UTC)
nikosman88
Greece
Any ideas?
Thank you so much
Yes i dont see also a way to auto-addinput a source like this you want. The only way to do this is to load a preset that will have inside allready this source, so it will load this input. There exist in vmixapi a command that can open a vmix preset but unfortunatelly not a command that will append a vmix preset. So if you send this command will interrupt your 24/7 stream and then you`ll need and other commands to send to pgm the correct input,make again streaming etc....
An idea i have for this problem.. If you have a spare pc you can load there vmix hd version (60$) and then send to main pc ndi output and in main pc make scripts that will send to 2nd pc the http command to change the preset with and without the ip camera in the time you need.
This thing can also be done in same pc if you enable the multiple vmix instances and it needs some more complicated way to achieve your goal, but i think possible to be done
thanks 1 user thanked nikosman88 for this useful post.
xlamano on 7/31/2023(UTC)
xlamano
#5 Posted : Friday, July 21, 2023 7:20:17 PM(UTC)
xlamano
Spain
Thank you very much for answering so quickly @nikosman88, I love the vMix community!
It would be ideal to make APPEND of a preset that only has the RTSP cameras, in this way they could be closed by script, and later add them again at the time we want to reconnect them
Finally we will do the following solution inspired by your feedback:
We will program a windows task so that at a specific time it execute an API call (throught PowerShell) to execute an script that 1: stops the streaming and 2: loads a new preset that does NOT contain the IP cameras
We will add a browser type source to the new preset so that it executes a script called STARTUP that restarts the streaming once the preset is opened
https://forums.vmix.com/...-Run-a-script-at-startup
We can't avoid cutting streaming for a few seconds, but I think it's a good solution
And we will repeat the same process to resume the cameras again: at a specific time a windows task execute an API call that stops streaming and loads the original preset with the cameras
mavik
#6 Posted : Tuesday, July 25, 2023 12:11:02 AM(UTC)
mavik
Just a stupid idea.
You can approach this from the network side as well, I think. Block the remote rtsp stream on the firewall/router side at a given time. Everything could stay as is, just no traffic. Then at whatever time you open the connection again.
Mikrotik routers can do this very easily.
xlamano
#7 Posted : Monday, July 31, 2023 11:20:15 PM(UTC)
xlamano
Spain
Originally Posted by: mavik Go to Quoted Post
Just a stupid idea.
Thank you too mavik! The idea is not that stupid. I think it would be possible to do it with the windows task scheduler. The only thing that I think would be a reset in the RTSP INPUT to reconnect the source when the firewall allowed it again
