how to add and hear audio from rtsp flux camera
Hello everyone, i have ip camera that have rtsp flux with audio integrated, on vlc player i can hear without problems, but in vmix i can't hear anything. you can help me with any solution?
Thank you more, Al.
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
I believe vMix only supports streams using AAC audio using its RTSP input.
With the stream playing in VLC have a look at Tools -> Media Information -> Codec to see what audio format it is sending - probably G.711
If you change the stream input in vMix to use the VLC type rather than RTSP Over UDP/TCP then that may well play the audio.
thank you Rich for your reply, yes, i check it and the audio it's made by PCM ALAW g.711. you can explain me how it's possible import in vmix?
Very thanks
Choose Add Input Choose Stream Change the Stream Type to VLC Enter your rtsp address like you did before
I'm pretty sure that has worked for me with a G.711 camera
