pagu
#1 Posted : Thursday, April 18, 2019 6:38:12 PM(UTC)
pagu
Hello everyone,
i have ip camera that have rtsp flux with audio integrated, on vlc player i can hear without problems,
but in vmix i can't hear anything.
you can help me with any solution?
Thank you more,
Al.
RichDanby
#2 Posted : Thursday, April 18, 2019 7:20:21 PM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
I believe vMix only supports streams using AAC audio using its RTSP input.
With the stream playing in VLC have a look at Tools -> Media Information -> Codec to see what audio format it is sending - probably G.711
If you change the stream input in vMix to use the VLC type rather than RTSP Over UDP/TCP then that may well play the audio.
pagu
#3 Posted : Friday, April 19, 2019 12:53:52 AM(UTC)
pagu
thank you Rich for your reply,
yes, i check it and the audio it's made by PCM ALAW g.711.
you can explain me how it's possible import in vmix?
Very thanks
RichDanby
#4 Posted : Friday, April 19, 2019 12:58:25 AM(UTC)
RichDanby
Choose Add Input
Choose Stream
Change the Stream Type to VLC
Enter your rtsp address like you did before
I'm pretty sure that has worked for me with a G.711 camera
