pjarbo
#1 Posted : Saturday, December 11, 2010 7:45:50 AM(UTC)
pjarbo
Hi all!
Short introduction since this is my first post.
My name is Petter Jarbo, I'm TD (volunteer) at my church in the south of Sweden. We started a videoministry a year ago and we've just got it running.
We are currently using a Datavideo SE500 with two Panasonic DVX100B and a computer with a BMD Intensity Pro for capture. We are in the process of purchasing two new (or used) cameras and are leaning towards a couple of JVC GY-HD251.
We need a new mixer! Enter vMix, and I am impressed! A nice member gave us his used i7 computer (state of the art everything when the i7 came out)
To my question: Have anyone used the Decklink Duo? Can vMix use both inputs from this single card? I would like to do a six camera system, but the number of pci-e ports hinder us.
Thank you!
Petter
#2 Posted : Saturday, December 11, 2010 9:40:55 AM(UTC)
Was thanked: 4688 time(s) in 1611 post(s)
Hi Petter,
The Decklink Duo should work fine with vMix as we support all DeckLink and Intensity cards.
That specific card hasn't been tested though, so if you run into any issues I would be happy to offer any assistance to get it working for you.
pjarbo
#3 Posted : Saturday, December 11, 2010 9:52:42 AM(UTC)
pjarbo
Sounds great!
My specific question about this card is if I can use it for two cameras simultaneously.
From the BMD site "DeckLink Duo is perfect for developers who need two completely independent capture and playback streams in and out of a computer, as both capture and playback channels are completely independent. "
That means I could do a 8 camera mixer with my computer :-)
Thanks!
Petter
pjarbo
#4 Posted : Tuesday, December 14, 2010 6:44:01 AM(UTC)
pjarbo
Martin, since I'm thinking of buying this card and I don't have the money to spend if it wont work as I hope it will, should there be any trouble using both inputs simultaniously on the Decklink Duo?
I understand it hasn't been tested, but in your considerable experience with the code of vMix, could there be any problems, should I spend my money on the cheaper SDI instead?
I will not have enough money to buy the full version of vMix this year, but if our tests pans out, we will spend the money next year. Sofar, I'm impressed!
Best regards
Petter
#5 Posted : Tuesday, December 14, 2010 8:48:35 AM(UTC)
The DeckLink Duo should work with both inputs in vMix straight out of the box.
If it doesn't there will only be a minor tweak required to get it to work with vMix, and I would be happy to make any adjustments as required.
As for running 8x cameras out of 4 cards, as long as you have plenty of memory bandwidth (DDR3 1066 or higher) and a fast processor (Core i7) it should be ok.
Just note that the duo requires a PCI-E x4,x8 or x16 port.
pjarbo
#6 Posted : Tuesday, December 14, 2010 9:51:42 AM(UTC)
pjarbo
Thanks Martin!
I'm not actually planning on installing 4 of them at once. I will start with one and beef the machine with two Intensity pro too. Eventually I will want to get at least two more Duo cards for a six camera setup, but that's for the future.
Thanks for the heads up on the Duo requiring x4 or above. Wasn't aware of it. Will have to factor in a new MB when I get the next Duo :)
Will give update when the card is installed and running.
Great help around here! Whish all software developers were as forthcoming with information as you.
Thanks!
Petter
Similar Topics
Green line at top and bottom when using DeckLink Duo 2 Fill/Key output in vMix (1080i59.94) (Hardware Compatibility)
by ken5o 2/14/2026 8:26:42 PM(UTC)
DeckLink Duo Not Showing as Input in vMix After Fresh Windows Install (Hardware Compatibility)
by jbragancapt 7/29/2025 6:34:23 PM(UTC)
Issue Decklink Duo 2 and desktop video 14.3 (only legacy wdm input vmix) (Hardware Compatibility)
by julien 11/27/2024 12:14:34 AM(UTC)
Sending Key/Fill and Video from Decklink Duo 2. Is it possible? (Hardware Compatibility)
by fva 8/29/2024 2:09:37 AM(UTC)
Decklink Duo 2 Input Problem (Hardware Compatibility)
by dny18 5/12/2024 7:33:14 PM(UTC)
Problem with 2 Decklink Duo 2 cards (Hardware Compatibility)
by filmmaker75 2/5/2024 9:04:11 PM(UTC)
vMix External Output to Decklink Duo problems (General Discussion)
by Bamboo 11/6/2023 2:48:25 AM(UTC)
Decklink Duo 2 Output Settings (General Discussion)
by obcocav 5/22/2023 7:11:14 AM(UTC)
2X Decklink Duo 2 and 2X Sonnet Echo Express SE1 (Hardware Compatibility)
by EvilAsh80 2/16/2022 12:10:49 AM(UTC)
Dell PC distorted audio output to Decklink Duo 2 (Hardware Compatibility)
by ibwalkn 1/27/2022 5:25:38 AM(UTC)
Help with Decklink Duo inputs and output (Hardware Compatibility)
by sacchin 1/22/2022 8:08:04 PM(UTC)
DeckLink Duo 2 Not working (General Discussion)
by CyberPunk1232 11/27/2021 1:39:49 PM(UTC)
2 inputs working, 2 inputs not working with Decklink Duo 2 card (Hardware Compatibility)
by ThomasWallis 11/13/2021 5:36:18 AM(UTC)
Decklink Duo 2 dropping frames?? (Hardware Compatibility)
by KirenPollard 10/8/2021 6:28:58 PM(UTC)
Decklink Duo 2 dropping frames (Hardware Compatibility)
by svetotehnik 5/13/2021 5:04:02 PM(UTC)
Decklink Duo2 resolution issue (Hardware Compatibility)
by zonuna 3/6/2021 4:46:47 PM(UTC)
Black Magic Decklink Duo 8 IN/OUT Audio Challenge (Hardware Compatibility)
by epeters 1/26/2021 3:03:37 AM(UTC)
Error with input from BlackMagic Decklink Duo 2 (Hardware Compatibility)
by gmm920 1/13/2021 2:24:13 AM(UTC)
No audio on first input of Decklink Duo 2 (Hardware Compatibility)
by rehofman 1/4/2021 8:50:41 PM(UTC)
Blackmagic Decklink Duo - Always needs to be re-added after restart (General Discussion)
by Ashkal 10/6/2020 10:49:49 PM(UTC)
Decklink Duo 2 Embedded Audio Output (Hardware Compatibility)
by ARSP 8/19/2020 10:57:04 AM(UTC)
dropped Frames with Decklink Duo2 and vMix 23.0.0.57 (General Discussion)
by newmans 6/8/2020 4:54:27 AM(UTC)
BM Decklink Duo 2 or Magewell Pro Capture Quad SDI with Sony PXW (Hardware Compatibility)
by A_palmre 5/31/2020 6:32:10 PM(UTC)
Blackmagic Decklink Duo 2 and Sony EVI-HD1 (Hardware Compatibility)
by GraceMaryville 4/10/2020 7:55:21 AM(UTC)
BMD Decklink Duo 2 and Avipas PTZ camera (Hardware Compatibility)
by Riculus 1/19/2020 4:20:31 AM(UTC)
Atem vs Blackmagic design decklink Duo 2 (Hardware Compatibility)
by Riculus 1/8/2020 1:04:45 PM(UTC)
Output with Blackmagic Decklink Duo2 (General Discussion)
by dgitygp 12/28/2019 9:01:22 AM(UTC)
[SOLVED] Decklink Duo 2 / Sonnet / Thunderbolt - Audio Problem (Hardware Compatibility)
by mundm 10/17/2019 2:12:37 AM(UTC)
Decklink Duo 2 set up (Hardware Compatibility)
by ElBurrito 9/6/2019 11:31:39 AM(UTC)
Can I capture 1080p60 using Blackmagic Design DeckLink Duo 2 and PTZOptics 12X 1080p HD-SDI ? (Hardware Compatibility)
by vhilly27 8/18/2019 4:58:46 PM(UTC)
