gianlucadario
#1 Posted : Saturday, January 9, 2016 5:35:36 PM(UTC)
gianlucadario
good evening.
i'm new in this forum. And new with vmix.
I installed Vmix. and I'm trying. since it is the only software mixing video working good(in theory).
I'm going to buy it in near future. But only if he fulfills.
I added 7 videos.
I put one in the preview and then to the live and it works (both audio and video)
I put the second video in the preview, and then in the show live and works only the video but not the audio.
I tried with all videos with different order. The first always works. the second and subsequent never work!
I ask you for an important support 'cause I have to use this program on Sunday morning.
thank you!
Gianluca from Italy
Siroki
#2 Posted : Saturday, January 9, 2016 6:03:39 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
gianlucadario wrote:
good evening.
I added 7 videos.
thank you!
Gianluca from Italy
When you switch to another video in right up player that video should play and in the bottom where modules are (video list) you have after 1 2 3 4, Ausio and it needs to be green. If not you need to set up that Audio switches on another video..Its hard to explain here because we don't know how you setup the program.
Can you install and give Teamviewer code so someone can attach to your PC and see whats the problem
You can send me on PM if you wanna
bye
#3 Posted : Sunday, January 10, 2016 1:05:13 AM(UTC)
@ gianlucadario
Assuming all the files have audio and play fine outside of vMix, the first thing to check is the "General Settings" of each video 'Input' (cog wheel button) and make sure that the "Automatically mix audio" box is ticked.
Similar Topics
Audio problem only in 1080p and output (Hardware Compatibility)
by Michellav 10/22/2025 12:29:49 AM(UTC)
Duplicate Audio Problem in vMix (General Discussion)
by Adelado 9/10/2025 11:57:15 PM(UTC)
Audio problems when playing audio content (General Discussion)
by RickyFreak98 12/3/2024 11:36:29 AM(UTC)
Vmix Audio Problem (General Discussion)
by adrianpanleo 10/8/2024 10:09:56 AM(UTC)
vMix-NDI-Zoom Audio Problem (General Discussion)
by coop 5/29/2024 8:29:01 AM(UTC)
Audio problems live stream fb, Insta (General Discussion)
by mpoi 3/1/2024 7:52:55 PM(UTC)
PTZ Network audio problem (Hardware Compatibility)
by ForbJM 1/17/2023 1:32:11 AM(UTC)
Audio problems (clicking noises) (General Discussion)
by SebastianVinia 2/15/2022 1:55:03 AM(UTC)
Internet Audio Problem (vMix Call)
by coop 12/22/2021 12:15:05 AM(UTC)
audio problem with preview (General Discussion)
by givros 7/16/2021 7:11:05 PM(UTC)
Magewell USB / HDMI capture embedded audio problem (Hardware Compatibility)
by Jason Vaughan 4/25/2021 6:56:45 AM(UTC)
Livestream Audio Problems (General Discussion)
by Harvest Tab 3/6/2021 6:54:22 AM(UTC)
audio problems with Blackmagic card Broadway tabernacle (General Discussion)
by JohnDev 10/5/2020 4:56:57 AM(UTC)
[SOLVED] Decklink Duo 2 / Sonnet / Thunderbolt - Audio Problem (Hardware Compatibility)
by mundm 10/17/2019 2:12:37 AM(UTC)
Audio Problem Pre / Post (General Discussion)
by Slaver 3/5/2019 12:39:40 AM(UTC)
Vmix Go Plus Audio problem (Systems)
by Vizsuall 2/26/2019 6:32:01 PM(UTC)
Web Browser Input Audio Problem (General Discussion)
by r5dad 1/15/2019 12:55:55 PM(UTC)
Multiple Camera follow Audio Problem (General Discussion)
by maven2 7/17/2018 1:47:47 AM(UTC)
by gefiltafish 3/22/2018 2:54:57 PM(UTC)
Audio problem (General Discussion)
by soundguy 10/28/2017 2:22:56 PM(UTC)
Multiple instances audio problem (General Discussion)
by Epag 10/27/2017 7:10:46 PM(UTC)
MAB 6ch audio problem with SpeedHQ (General Discussion)
by Ittaidv 7/24/2017 9:45:57 AM(UTC)
Zoom webinar audio problem (General Discussion)
by HWL1223 2/16/2017 11:47:55 AM(UTC)
Update your decklink drivers, audio problems are gone. (Hardware Compatibility)
by Mathijs 11/2/2016 10:02:54 AM(UTC)
Vmix 16 Audio Problem Windows 10 Pro (General Discussion)
by macgiver76 9/19/2015 2:23:40 PM(UTC)
recording audio problem prores (General Discussion)
by pierre 9/11/2015 10:18:15 AM(UTC)
Vmix RTSP audio problem (General Discussion)
by Allen Tang 5/13/2015 4:07:11 AM(UTC)
continued audio problems (General Discussion)
by zentriloquy 4/20/2015 9:17:19 AM(UTC)
Derklink 4 K extreme audio problem (General Discussion)
by i hacked 1/7/2015 11:35:32 AM(UTC)
Audio Problem- need help (General Discussion)
by JB 6/25/2014 12:32:14 AM(UTC)
