mikeel74
#1 Posted : Wednesday, November 4, 2015 11:33:34 PM(UTC)
mikeel74
Good day every one!
Need help please...
Im using vmix 14 and i experience lagging every time i turn on fullscreen..dual monitor
screen size 1920x1080 . im using nvdia GT630 4G.
Should I replace my graphics card or buy hardware as external renderer.
i need at least 1 HDMI output and analog output if possible
Thanks...
MIKE
#2 Posted : Thursday, November 5, 2015 2:54:51 AM(UTC)
@ mikeel74
Upgrading your graphics card might be the solution, but perhaps providing a few more details about your system, your set-up and your 'needs & wants' will assist in assessing what your best options will be.
GeorgeR
#3 Posted : Thursday, November 5, 2015 3:35:47 AM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
mikeel74 wrote:
Good day every one!
Need help please...
Thanks...
MIKE
Mike you might try reducing the size of your external output to 1280x720. Another consideration is how many inputs you have in vMix. Each input, including the external output, draws resources from your computer.
There are two important benchmarks within vMix. One is the CPU. If the CPU is over 70% it indicated the CPU is overloaded. The other is render time. If the render time is at or over 20ms then your graphic card is overloaded.
This information can be found in the bottom left corner in vMix.
Happy vMixing!
~George
mikeel74
#4 Posted : Thursday, November 5, 2015 4:20:52 AM(UTC)
mikeel74
Thank you for the reply sir.
Im using Magewell Xi400-SDI as input device, with 3 HD cams active, my cpu is corei 7. Is my GT630 graphics card enough to handle this load?
Im am planning to utilize my remaining 1 SDI input, All vmix function works ok when fullscreen is off..but when its on, cpu & latency suddenly increase,freezes(while editing titles, selecting cam as preview).
Yes, I already tried to reduce the output size but did not solved the issue..
although i haven't yet tried to reduce the screen size output for my monitor.(2x 1920x1080)
I really need to turn on the fullscreen for i will use it for realtime broadcast. We are a small CATV co. here in the Philippines and
were using vmix for our community channel..
ovinas
#5 Posted : Thursday, November 5, 2015 8:56:59 AM(UTC)
ovinas
First thing to do is updating to current version 16!
tesn
#6 Posted : Sunday, December 6, 2015 3:14:31 PM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
Just thought I'd throw out there that I noticed my render time going from 5ms . . . to 35ms when I turned Fullscreen on.
I lowered the resolution of my output monitor to 1024x768 (from 1920x1080). And my render time went back down to 5-8ms.
And I recently installed a new GeForce GTX 980 Ti.
Luckily my output is only 854x480, but I'm a little surprised the 980 can't handle the load.
-Brian
Rizotochaud
#7 Posted : Monday, December 7, 2015 5:50:49 PM(UTC)
Rizotochaud
I have a similar problem with the latest version. I explained it all in this topic : http://forums.vmix.com/d....aspx?g=posts&t=5513
However, since the latest update (0.108), vMix doesn't freeze/crash anymore, but still, the footage becomes laggy with the time, with many framedrops in the Statistics window.
This problem occurs only when my VMix Output Resolution is 1080p, but works fine when I'm in 720p.
Similar Topics
Fullscreen output resolution (General Discussion)
by adambou 8/29/2026 8:29:11 PM(UTC)
fullscreen output NDI (Feature Requests)
by christianb 2/7/2026 8:21:10 AM(UTC)
HDMI fullscreen output looks unsharp (and how I solved it) (General Discussion)
by Pepsi(~) 5/23/2025 1:58:39 AM(UTC)
Fullscreen output to 7680x1080 mosaic possible? (Hardware Compatibility)
by hdj912 3/10/2024 7:05:06 PM(UTC)
Fullscreen Output2 (Feature Requests)
by gefiltafish 2/14/2024 9:49:44 PM(UTC)
Monitor #s and Fullscreen outputs (Feature Requests)
by obcocav 5/24/2023 8:54:35 PM(UTC)
Prevent Fullscreen outputs from "dimming" on Windows notifications (General Discussion)
by KDNWK 10/26/2022 7:48:39 AM(UTC)
Fullscreen output monitor #'s (General Discussion)
by obcocav 7/25/2022 11:17:44 PM(UTC)
fullscreen output by internal hdmi (General Discussion)
by elbex 11/20/2021 12:32:09 AM(UTC)
Fullscreen Output via graphics card (General Discussion)
by LifeOfStew 4/10/2021 5:12:29 AM(UTC)
Make Fullscreen output programable trigger and shortcut (Feature Requests)
by rweeks 3/13/2021 1:57:37 PM(UTC)
Changing Fullscreen Output 1 (General Discussion)
by Chris Daum 1/21/2021 7:30:21 PM(UTC)
Fullscreen Output 1 & 2 (General Discussion)
by Andreas Jaenisch 11/13/2020 9:21:53 PM(UTC)
Productions clock on fullscreen output (General Discussion)
by Edsard 9/10/2020 5:32:48 AM(UTC)
Can't change Fullscreen output 1 (General Discussion)
by Tone13 4/22/2020 4:46:28 PM(UTC)
Showing Clock as an Overlay on Fullscreen Output Only (General Discussion)
by RickDPWV 7/13/2019 6:38:47 AM(UTC)
Fullscreen output flashing on primary screen (General Discussion)
by limonoah 2/24/2018 9:09:10 PM(UTC)
Fullscreen output is reversed (General Discussion)
by UFGraymatter 7/30/2017 2:43:34 PM(UTC)
External Output + Fullscreen output (General Discussion)
by nilgarcia0 1/19/2017 3:11:57 PM(UTC)
Add external output 2 and fullscreen output activators (Feature Requests)
by Mathijs 12/30/2016 12:31:31 PM(UTC)
3rd fullscreen output (Feature Requests)
by Mathijs 6/11/2016 1:12:26 PM(UTC)
vMix freezes when fullscreen output is 1080p (General Discussion)
by Rizotochaud 11/30/2015 3:24:53 PM(UTC)
Include audio in Fullscreen output (General Discussion)
by lyinawake 5/3/2015 1:59:34 PM(UTC)
Fullscreen output on display2 (General Discussion)
by gegraham 4/16/2015 8:53:07 PM(UTC)
Poor performance using Fullscreen output (General Discussion)
by lyinawake 4/15/2015 12:52:30 PM(UTC)
Second FullScreen output when only 1 allowed (General Discussion)
by ihtus 12/3/2014 11:16:08 AM(UTC)
Jittering when using 2 fullscreen outputs (General Discussion)
by richardgatarski 11/26/2014 2:25:36 PM(UTC)
Fullscreen outputs, free rotation (Feature Requests)
by jehvi 9/2/2014 4:54:59 AM(UTC)
