Changing Fullscreen Output 1
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
maybe this has been posted, and I just could not find it...
I have the Problem that I can not change the source of Fullscreen Output 1.
It always results in FS OUT 1 showing Output 1. The drop down next to the fullscreen button, adjusting in "Settings, Output", scripting nothing worked.
Is that my personal problem, that I can´t change that issue (cause not capable of :-)) or is there a technical issue?
Set Up is Deck Link Card SDI as 2 x IN / 2 x OUT Internal Graphic card 2 x Display (User Interface, PRV FS 1) / 1 x Signal Management FS 2 (Auqilon)
@ CHris Daum
vMix needs an outlet for its Program Output, normally, this is Output 1. If that is set so something other than "Output", then the Fullscreen Output will default and lock to "Output" and won't be changeable.
thanks for your answer! That´s an explanation...
I already thought about something like that and routed the Output to EX OUT 3. But it is still locked.
But OK I understand the issue...
