Chris Daum
#1 Posted : Thursday, January 21, 2021 7:30:21 PM(UTC)
Chris Daum
Germany
maybe this has been posted, and I just could not find it...
I have the Problem that I can not change the source of Fullscreen Output 1.
It always results in FS OUT 1 showing Output 1.
The drop down next to the fullscreen button, adjusting in "Settings, Output", scripting
nothing worked.
Is that my personal problem, that I can´t change that issue (cause not capable of :-))
or is there a technical issue?
Set Up is
Deck Link Card SDI as 2 x IN / 2 x OUT
Internal Graphic card 2 x Display (User Interface, PRV FS 1) / 1 x Signal Management FS 2 (Auqilon)
#2 Posted : Thursday, January 21, 2021 9:54:47 PM(UTC)
@ CHris Daum
vMix needs an outlet for its Program Output, normally, this is Output 1.
If that is set so something other than "Output", then the Fullscreen Output will default and lock to "Output" and won't be changeable.
Chris Daum
#3 Posted : Thursday, January 21, 2021 10:12:46 PM(UTC)
Chris Daum
Germany
thanks for your answer!
That´s an explanation...
I already thought about something like that and routed the Output to EX OUT 3.
But it is still locked.
But OK I understand the issue...
