Fullscreen output flashing on primary screen
We're seeing really strange behavior, the Fullscreen output is flashing on and off overtop of the main vMix window. We have 2 displays (extended desktop) connected to the AMD graphics card, and one Blackmagic Intensity Pro providing an External output. The External output is not affected. Interestingly, it only happens when the main vMix window is NOT maximized. Also, if we drag the main vMix window partially or completely on to the Secondary display, the flashing also stops.
This behavior start on Thursday, however there was no problem the day before. We dont think there were any updates or any config changes.
Some specs: Windows 10, AMD Radeon HD 6790, Core i7 960, 12GB RAM
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
Are you running the same rez/refresh on both monitors, I've seen something similar when the PC doesn't like creating 2 different rez/refresh rates.
This issue was resolved by changing the resolution of the secondary monitor. We also noticed that Windows did some updates just prior to the issue starting.
 1 user thanked limonoah for this useful post.
Joined: 9/13/2016(UTC) Posts: 112   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
there is such a problem! and began about the beginning of the release of 20 versions. stranger is that the screen starts blinking when adding vmix call inputs or a large (from 5) NDI inputs. Most of all this problem with Samsung monitors. and it blinks any the display where VMIX is deployed
i7-6950X / 128g memory / asus NV 1080 ti
limonoah wrote:This issue was resolved by changing the resolution of the secondary monitor. We also noticed that Windows did some updates just prior to the issue starting. You're welcome.
