Can't change Fullscreen output 1
Joined: 3/29/2020(UTC) Posts: 104  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Hi all, I'm trying to send the Multiview to Display1 as a fulscreen but it doesn't work. I always see the main output.
I select Display 1 > Multiview and then hit Fullscreen but nothing happens. I then go to Display 1 selection again and the main output is still ticked.
Any one had similar issues?
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Did you check Settings > Display > Fullscreen 1 (and if the correct screen is selected)?
