Michael7687
#1 Posted : Tuesday, February 27, 2024 12:11:07 PM(UTC)
Michael7687
I was wondering if there are any shortcuts that can be used with the Companion software and Stream Deck to open full screen inputs on Vmix and what and how do you enter the shortcut. Wish the input number?
richardgatarski
#2 Posted : Tuesday, February 27, 2024 5:58:01 PM(UTC)
richardgatarski
I don't understand your question. But you can always install Companion and try.
Michael7687
#3 Posted : Tuesday, February 27, 2024 10:40:13 PM(UTC)
Michael7687
I want to change an input on the Fullscreen in Is there a way to switch inputs on a second monitor by using Stream Deck and not having to use the drop-down menu, Fullscreen function in Vmix? In other words, When I am wanting to switch my inputs on the fullscreen to another monitor is there any way I can switch using Streamdeck?
dmwkr
#4 Posted : Tuesday, February 27, 2024 10:49:08 PM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
Several possibilities, but imo Mix Input is the way to go:
?si=SraX337Dt55UXIj9
Transition shortcuts also can be used with Mix inputs.
Similar Topics
Stream Deck no longer connecting to vMix via Companion (General Discussion)
by dobrodt 1/10/2026 3:20:01 AM(UTC)
Elgato Stream Deck Plus (General Discussion)
by hajandr 1/6/2026 4:32:43 AM(UTC)
NDI Camera Input Lagging Audio Input From Osee Stream Deck (General Discussion)
by Ron Carter 2/1/2025 1:39:24 AM(UTC)
Making use of stream deck+ dials (Feature Requests)
by Peter Ptassek 11/18/2024 6:49:16 PM(UTC)
Stream Deck REMOTE (Off-Site) control (General Discussion)
by Dave Cruickshank 9/18/2024 2:55:45 PM(UTC)
New Stream Deck (3rd Party Software and Development)
by profetauy 8/11/2024 7:22:49 AM(UTC)
Stream Deck + and ReplaySetSpeed adaptive increment (Feature Requests)
by rosen.5th 4/15/2024 7:47:12 PM(UTC)
Stream Deck + Feature Request (Feature Requests)
by BBA_MEDIA 4/11/2024 7:21:25 PM(UTC)
Companion Play/Pause preset for a stream deck (General Discussion)
by ab800 2/23/2024 7:18:50 AM(UTC)
Multiple input activators for one stream deck button (Feature Requests)
by crnaman77 2/22/2024 9:43:00 AM(UTC)
Vmix + Companion + Stream Deck + Google Sheets (General Discussion)
by ab800 2/22/2024 7:07:28 AM(UTC)
Elgato Stream Deck XL (Hardware Compatibility)
by Turnier 2/9/2024 5:35:28 AM(UTC)
Stream deck losing connection to vMix (General Discussion)
by liesports 1/2/2024 2:59:48 PM(UTC)
vMix Stream Deck (Hardware Compatibility)
by SDKUCSS 11/1/2023 10:02:32 PM(UTC)
Stream Deck + vol %/db on touch screen (Feature Requests)
by cody@raceontexas.com 10/18/2023 1:13:38 PM(UTC)
Thumbnail views on Stream Deck - Activators don't work (General Discussion)
by AuditorRSTO 7/20/2023 10:50:41 PM(UTC)
No Detection of Dails in Stream Deck + (Hardware Compatibility)
by TCC Video Ministry 5/10/2023 1:53:43 AM(UTC)
Stream Deck + compatibility (Hardware Compatibility)
by bdog 1/5/2023 8:38:33 AM(UTC)
by DJLTC 12/27/2022 12:15:58 PM(UTC)
Stream deck install issues for vMix plugin (3rd Party Software and Development)
by MarcoNL 11/16/2022 7:16:29 AM(UTC)
Setting stream keys with Stream deck (General Discussion)
by Olib 9/22/2022 11:55:54 PM(UTC)
Activators + Thumbnails on Stream Deck (Feature Requests)
by xavifumi 8/23/2022 4:59:14 PM(UTC)
Stream Deck button color change while recording (General Discussion)
by sebrame 5/6/2022 4:16:22 AM(UTC)
Shortcut question using Stream Deck (General Discussion)
by JohnnyBG 1/19/2022 9:23:56 AM(UTC)
Central audio channel strip with stream deck (General Discussion)
by pm 1/10/2022 2:07:33 AM(UTC)
Copy Shortcuts for Stream Deck (General Discussion)
by PaulV8 1/6/2022 8:56:59 PM(UTC)
Stream deck with Colors and Images (png)? Is it possible? (Feature Requests)
by Hall3008 1/6/2022 6:53:47 PM(UTC)
Stream Deck is broken for vMix (only) (3rd Party Software and Development)
by MediaNBC 12/25/2021 9:48:49 AM(UTC)
Switching Stream Decks (keep Shortcuts?) (General Discussion)
by BigApple 10/18/2021 11:50:05 AM(UTC)
Multi-Function Button Stream Deck (Feature Requests)
by stephencousins 10/15/2021 12:07:48 AM(UTC)
