                Has anyone had any success with setting up the new Stream Deck + to work with VMix for volume control?  I know this is a new piece of hardware.  It would be great if you could control volume on 4 sources with this unit.
 Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
                Devs said in vMix Live show that there is no documentation for developers for the device yet, so it will be a while before it works probably.
                Companion app now has control over stream deck dials and can be paired with Vmix. This is not a perfect solution but it works.
  So far I have not been able to show thumbnail of the broadcast on the stream deck using the companion app.
  Does anyone know if there's an update on this support issue.
 Joined: 7/6/2023(UTC) Posts: 3  Location: Nice Thanks: 2 times
                Hi guys, six months later, is there any news about the 2022 Stream Deck+ and especially its dials in vmix? I would like to use it for volume of course, but it would be fantastic if I can also use it to navigate in the replay videos to select more precisely the In and Out points.
                I saw that the Streamdeck+ is now compatible with the vmix 27 beta. Did someone test it and could tell me if we can control the markIn markOut point with the dials for the Instant Replay plugin? (in this case I'll go buy one immediately haha)
