Joined: 2/27/2024(UTC) Posts: 8  Location: Missouri Thanks: 2 times
I was wondering if there are any shortcuts that can be used with the Companion software and Stream Deck to open full screen inputs on Vmix and what and how do you enter the shortcut. Wish the input number?
I don't understand your question. But you can always install Companion and try.
I want to change an input on the Fullscreen in Is there a way to switch inputs on a second monitor by using Stream Deck and not having to use the drop-down menu, Fullscreen function in Vmix? In other words, When I am wanting to switch my inputs on the fullscreen to another monitor is there any way I can switch using Streamdeck?
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
Several possibilities, but imo Mix Input is the way to go: ?si=SraX337Dt55UXIj9 Transition shortcuts also can be used with Mix inputs.
