profetauy
#1 Posted : Sunday, August 11, 2024 7:22:49 AM(UTC)
profetauy
I have a Stream Deck working with vMix and works amazing...
I just purchased the iPad version for the Stream Deck (bigger and more keys)... I was able to copy all the keys from the StreamDeck, but now, of course, in vMix aren't working (in the iPad).
So far, the only solution that I found is duplicate the Shortcut and in the new one click on the app of the Stream Deck iPad button, so can works there.
There's an easy way of this? Maybe in vMix have the same shortcut that can be activated with 2 different buttons? Or something like that?
Thank you, will be great to avoid to copy over 200 shortcuts that I have for different shows.
richardgatarski
#2 Posted : Sunday, August 11, 2024 8:06:36 PM(UTC)
richardgatarski
Sorry, due to limitations in Elgato's API vMix shortcuts are tied to a unique Stream Deck device/app, see https://forums.vmix.com/...ix-22-Released#post62094
Instead I use the vMix plugin for Companion, which is really flexible although without vMix's thumbnail support.
profetauy on 8/12/2024(UTC)
