Andycam
#1 Posted : Tuesday, November 15, 2022 2:27:48 AM(UTC)
Andycam
Is this system any good for hd streaming with NDI and possibly a couple of sdi /hdmi ?
• Intel Core i5-4210M CPU @ 2.60GHz.
• Auto turbo upto 3.20GHz.
• 8GB DDR3L RAM.
• Brand new, ultra fast 256GB solid state drive.
• Intel HD Graphics 4600.
• AMD Radeon HD 8600M dedicated 2GB graphics.
• 2.4 and 5GHz WiFi. Bluetooth 4.0.
• Integrated 720p HD Webcam.
• SD Card reader. HDMI.
• USB 3.0. VGA. Backlit keyboard.
• Excellent battery life.
• Original Dell charger included.
• Windows 11 Pro 64-bit.
• Avast Anti-virus/Malware protection.
SportsNetUSA.net
#2 Posted : Wednesday, November 16, 2022 4:38:35 AM(UTC)
SportsNetUSA.net
That is a very old, very slow, 2 core CPU. Passmark score of 2879. By comparison old 4 core i7 systems with CPUs such as the 4710HQ, 4800MQ, 4810MQ are at about 6000 on the Passmark scale.
I have an HP ZBook laptop with a 4800MQ with vMix on it that is kind of a rental unit. It can do two channels of 1080P using a Thunderbolt 2 capture device, stream and record. But that's about the limit.
If you are thinking of buying that i5-4210M laptop for vMix, don't. If you're on a tight budget maybe you can find an older unit, such as a Dell G7 or an ASUS with a i7-8750H CPU. Also look for a laptop with NVIDIA graphics.
Andycam
#3 Posted : Wednesday, November 16, 2022 4:50:32 AM(UTC)
Andycam
Thanks for the advice. So much out there and it’s been a while since I had a pic. Been on MacBooks for a long time now.
Similar Topics
Best Practice - Upgrade + new laptop (General Discussion)
by w7psk 12/5/2025 4:04:22 AM(UTC)
1080/59.94 vMix laptop + thunderbolt PCIe suggestion from Youtube (Systems)
by trentr209 10/31/2025 12:44:31 PM(UTC)
Can I go with a cheap laptop or do I need to spend that extra €1k ? (Systems)
by Camille64 7/27/2025 2:31:23 AM(UTC)
Stuttering NDI on Dell Laptop (General Discussion)
by byevad 5/10/2025 7:59:38 PM(UTC)
vMix live IMAG via SDI inputs on a Thunderbolt 4 laptop - lowest latency option? (General Discussion)
by Paul CVP 10/3/2024 1:36:25 PM(UTC)
vMix on Framework laptops (Hardware Compatibility)
by TenSob_ 8/27/2024 8:29:48 PM(UTC)
no mention Resizable BAR in the Nvidia utility RTX4090 on a laptop (Hardware Compatibility)
by Pepsi(~) 5/15/2024 6:41:31 PM(UTC)
Looking for a new laptop to stream and record (Systems)
by bobbartholomew 3/30/2024 11:27:31 AM(UTC)
Zoom audio playing in laptop speakers (General Discussion)
by dobrodt 2/21/2024 6:51:26 AM(UTC)
USB-C Thunderbolt Video Capture Laptops (Hardware Compatibility)
by BETech 2/6/2024 9:27:38 PM(UTC)
I just had a vMix call from a laptop browser do 1080p... (General Discussion)
by SethLT 9/19/2023 6:16:58 AM(UTC)
Laptop, w/Ext monitor set to Duplicate -> Fullscreen blocks main control screen (General Discussion)
by FoolOnTheHill 5/15/2023 7:13:12 AM(UTC)
LAPTOP for VMIX (Hardware Compatibility)
by ELIM 4/24/2023 6:59:45 PM(UTC)
Laptop Configuration (Hardware Compatibility)
by Soapm 3/6/2023 5:33:12 PM(UTC)
Broadcast OutPut with LapTop Pc (Hardware Compatibility)
by etruxo 2/9/2023 9:38:48 PM(UTC)
Desktop capture/random skips to vmix laptop (NDI)
by _G3_ 12/20/2022 6:55:01 AM(UTC)
Return new Legion 7i laptop? No Resizable BAR! (General Discussion)
by VideoE 11/7/2022 5:50:55 AM(UTC)
Quick decision help needed - Laptop with RTX3050 or RTX A2000 GPU? (Systems)
by Machtl 10/12/2022 9:22:01 PM(UTC)
Is this Alienware laptop better than the 1 recommended by Vmix? (Systems)
by Rojo21 10/7/2022 12:06:11 AM(UTC)
Laptops with 240hz display (must run in 240hz)? (Hardware Compatibility)
by davelindmpls 9/24/2022 5:20:05 AM(UTC)
Laptop Graphic Card (General Discussion)
by guypriz 9/8/2022 12:27:49 AM(UTC)
Multiple HDMI cam inputs to laptop (Hardware Compatibility)
by pesi 8/14/2022 6:02:51 AM(UTC)
Intel 12th gen Laptops Discrete Graphics Mode?? (General Discussion)
by VideoE 7/30/2022 12:48:09 PM(UTC)
Be wary of Discrete Graphics Mode on Some Laptops (Hardware Compatibility)
by VideoE 7/30/2022 2:57:42 AM(UTC)
Thunderbolt 2 Devices on Thunderbolt 4 Laptop (Hardware Compatibility)
by Kelvin 6/29/2022 7:52:21 AM(UTC)
Laptops and windows 11 (General Discussion)
by VmixWithEvan 6/27/2022 4:19:06 AM(UTC)
Laptop / External Graphics Card / ISO Recordings (Hardware Compatibility)
by mpeveto1 5/17/2022 10:39:16 PM(UTC)
Replay on a laptop (Systems)
by tarek 4/11/2022 9:23:38 PM(UTC)
x4 HDMI Inputs on Laptop (Hardware Compatibility)
by SeanLP 3/12/2022 1:12:32 AM(UTC)
These new laptop GPU's got me saying Whaaaaat? (General Discussion)
by RichShumaker 1/19/2022 3:11:45 PM(UTC)
