ccolewilliam
#1 Posted : Monday, April 25, 2022 9:51:32 AM(UTC)
ccolewilliam
Hi- long time vmix user here love it. I am using vmix call. However, I pull our microphone audio back in via usb from our mixing board. When we use vmix call I add an audio input into vmix for the audio so the guest can hear the audio. BUT! the inputted audio gets remixed again with the callers audio and it's creating an echo. I have played with everything. Is there not a way to make the audio back into the system as like a monitor only. I have tried solo but that kills all of the audio.
zenvideo
#2 Posted : Monday, April 25, 2022 7:44:26 PM(UTC)
zenvideo
Is that audio feed just your microphone, or is it a mix of the microphone plus other things? (And if so, what other things?)
What is "the audio" that you're feeding into a vMix audio input so the guest can hear it? What does it consist of, where does it come from, and how are you sending it to the guest? It's really not clear, but it might be related to your problems.
What sources are in the echo? Is the the caller's audio, or the contents of the feed that you're sending to them?
Again, What are you referring to as "the audio" here? And "back into the system" - from where? You can make any vMix audio input just a "monitor only" by only feeding it to the Headphone mix but NOT going to the Master or any of the busses/groups A-G, plus you should generally ensure that the audio device used by the Headphone mix is not also being shared/used by another vMix group (eg. Master), otherwise it gets difficult to work out what sources you're actually listening to. Then you can set up a headphone mix of whatever you want to listen to, independent of the Master. You can also do the same sort of thing by using any unused audio bus (A - G) as a monitor mix/group.
Similar Topics
Vmix Call Audio Issue (vMix Call)
by sud 12/2/2025 8:16:30 PM(UTC)
Vmix call audio workflow (vMix Call)
by Pingutheman 2/16/2022 4:23:52 AM(UTC)
vMix Call to vMix Call audio quality & bitrate (vMix Call)
by CrimsonAvenger 4/17/2021 10:04:35 PM(UTC)
vMix Call Audio Drop Sync? (vMix Call)
by SHMD 4/9/2021 2:00:53 AM(UTC)
vMix Call audio dropouts (vMix Call)
by SethLT 3/30/2021 3:37:31 AM(UTC)
Vmix Call Audio Send and return to and from ASIO Channels (Feature Requests)
by Josef Hackl 1/21/2021 9:54:04 PM(UTC)
vMix Call audio-only and viewer-only (Feature Requests)
by bacu89 10/14/2020 12:39:28 AM(UTC)
Vmix Call audio not working (vMix Call)
by PTVChannel0 9/16/2020 10:45:55 AM(UTC)
vMix Call Audio Ducking (vMix Call)
Belarus scareacon 8/16/2020 3:45:29 AM(UTC)
Vmix call Audio Routing (vMix Call)
by jcw718 8/14/2020 7:22:28 AM(UTC)
Vmix Call audio issues Echo/No audio (vMix Call)
by mjasen 6/11/2020 3:34:21 AM(UTC)
vMix Call Audio Quality (vMix Call)
by ussnass1 5/12/2020 1:53:12 AM(UTC)
vmix call audio routing workflow (vMix Call)
by lighting video 3/31/2020 3:36:25 AM(UTC)
Vmix Call audio streaming quality (vMix Call)
by ranz 10/25/2019 4:34:58 PM(UTC)
Multicorder and vMix Call audio sync (vMix Call)
by mkrigsman 7/26/2019 2:00:37 AM(UTC)
Is it a good idea to send vMix call audio to Bus A or B? (vMix Call)
by rowby 3/21/2018 2:41:42 PM(UTC)
vMix Call Audio Only (Wireless In-Ear Monitoring) (Feature Requests)
by PTZOptics 2/11/2018 12:21:19 PM(UTC)
vMix Call Audio to guest not coming through and quality (vMix Call)
Belarus TrentisN 6/14/2017 12:00:52 AM(UTC)
vMix Call Audio from guest problem (vMix Call)
Belarus MattiaCC 5/26/2017 11:08:42 AM(UTC)
vMix Call Audio Solution Needed for Studio Guests (vMix Call)
by HowardAtO 5/6/2017 2:34:14 PM(UTC)
vMix Call Audio Only Option (Feature Requests)
by sunkast 3/17/2017 8:06:04 PM(UTC)
VMIX Call Audio and Video seems always out of sync (vMix Call)
by ubietymediasolutions 3/17/2017 5:54:45 PM(UTC)
Vmix call audio questions (vMix Call)
by Cormac 3/3/2017 6:22:16 AM(UTC)
