Joined: 10/5/2015(UTC) Posts: 47  Location: Norman, Oklahoma
Hi- long time vmix user here love it. I am using vmix call. However, I pull our microphone audio back in via usb from our mixing board. When we use vmix call I add an audio input into vmix for the audio so the guest can hear the audio. BUT! the inputted audio gets remixed again with the callers audio and it's creating an echo. I have played with everything. Is there not a way to make the audio back into the system as like a monitor only. I have tried solo but that kills all of the audio.
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Originally Posted by: ccolewilliam  I pull our microphone audio back in via usb from our mixing board. Is that audio feed just your microphone, or is it a mix of the microphone plus other things? (And if so, what other things?) Originally Posted by: ccolewilliam  When we use vmix call I add an audio input into vmix for the audio so the guest can hear the audio. What is "the audio" that you're feeding into a vMix audio input so the guest can hear it? What does it consist of, where does it come from, and how are you sending it to the guest? It's really not clear, but it might be related to your problems. Originally Posted by: ccolewilliam  BUT! the inputted audio gets remixed again with the callers audio and it's creating an echo. I have played with everything. What sources are in the echo? Is the the caller's audio, or the contents of the feed that you're sending to them? Originally Posted by: ccolewilliam  Is there not a way to make the audio back into the system as like a monitor only. I have tried solo but that kills all of the audio. Again, What are you referring to as "the audio" here? And "back into the system" - from where? You can make any vMix audio input just a "monitor only" by only feeding it to the Headphone mix but NOT going to the Master or any of the busses/groups A-G, plus you should generally ensure that the audio device used by the Headphone mix is not also being shared/used by another vMix group (eg. Master), otherwise it gets difficult to work out what sources you're actually listening to. Then you can set up a headphone mix of whatever you want to listen to, independent of the Master. You can also do the same sort of thing by using any unused audio bus (A - G) as a monitor mix/group.
