Miko242
#1 Posted : Wednesday, January 6, 2021 1:43:19 AM(UTC)
Miko242
Switzerland
hi there
I have the following problem.
As a test I got two Sony PTZ cameras that I wanted to control with VMix. (1x BRC-400, 1x SRG-X120)
Both I connected with SDI via a Decklink card, as well as via LAN with the computer.
The signal routing worked fine both with SDI and via RTSP.
Control via the Sony software (HTML page) also worked well.
But when I tried to activate the cameras via the PTZ control of VMIX (CGI) I got an Error 403 with one camera and an Error 401 with the other camera. I also tried different settings with fixed IP or DHCP, but unfortunately without success.
Would anyone have an idea where the problem could be?
Thanks in Advance
Miko
dmwkr
#2 Posted : Wednesday, January 6, 2021 2:25:33 AM(UTC)
dmwkr
Was thanked: 147 time(s) in 132 post(s)
Maybe try the Visca over IP protocol? This seems to be the one for your cameras:
https://www.vmix.com/help23/PTZPanTiltZoom.html
thanks 1 user thanked dmwkr for this useful post.
Miko242 on 1/30/2021(UTC)
Guest (4)
Similar Topics
Ptz controller in vmix (General Discussion)
by LAEM77 2/24/2024 6:43:53 AM(UTC)
Virtual PTZ control with Birddog P4K problems (Hardware Compatibility)
by Sacha Goodwin 2/22/2024 10:16:24 PM(UTC)
Zoom PTZ control (Feature Requests)
by fgolman 2/12/2024 12:48:00 AM(UTC)
PTZ control over NDI / Kiloview encoder (NDI)
by ckvideo 1/9/2024 11:35:44 PM(UTC)
Iris, gain and shutter on PTZ controller (Feature Requests)
by Geir Otto 3/29/2023 11:36:17 PM(UTC)
PRESETS & Joy Gen4 PTZ Controller (General Discussion)
by iampatrick 3/4/2023 11:25:15 PM(UTC)
Ptz controller camera slow velocity zoom Pan tilt (Hardware Compatibility)
by aci85 1/14/2023 7:04:28 PM(UTC)
PTZ Control VISCA Analog (Hardware Compatibility)
by Huaba 12/10/2022 4:43:42 AM(UTC)
Lumens VCA 50P no PTZ control using VISCA over IP (Hardware Compatibility)
by ckvideo 10/28/2022 12:01:30 AM(UTC)
PTZ Controls Canon CR N300 (General Discussion)
by elpicaro 10/24/2022 11:52:10 PM(UTC)
Laggy joystick PTZ control (General Discussion)
by lanceyoder 10/7/2022 12:31:08 AM(UTC)
PTZ Control question (also v24 to 25) (General Discussion)
by MarkNF82 7/2/2022 9:44:42 PM(UTC)
PTZ Control position Speed setting (General Discussion)
by doggy 6/16/2022 7:15:32 PM(UTC)
Make them play better together: vMix PTZ / Superjoy (external PTZ control) (Feature Requests)
by bbbullock 12/11/2021 10:43:47 AM(UTC)
CCTV PTZ Controls (General Discussion)
by Simsyuk 11/21/2021 1:58:48 AM(UTC)
Panasonic External Joystick PTZ controller and NDI cameras (General Discussion)
by ninomusica 6/2/2021 9:05:43 AM(UTC)
PTZ control for Vaddio cameras (Feature Requests)
by Mharvey 2/10/2021 3:02:42 AM(UTC)
Getting PTZ Control using Obsbot Tiny USB Camera with vMix... (General Discussion)
by PopisDad 12/6/2020 10:51:40 PM(UTC)
PTZ controll wb var auto manual (Feature Requests)
by bram van nevel 11/6/2020 6:55:28 AM(UTC)
PTZOptics camera PTZ control loses connection (General Discussion)
by Jawad Saadi 10/15/2020 11:51:26 PM(UTC)
PTZ Controls in vMIX HD (General Discussion)
by bscarbrough1903 9/25/2020 5:40:19 AM(UTC)
Onscreen PTZ control (Feature Requests)
by SinRoma 5/19/2020 5:19:01 PM(UTC)
Point and Click PTZ control (Feature Requests)
by MediamanNYC 1/29/2020 1:59:31 AM(UTC)
PTZ control of Focus/Iris for Panasonic AW-HE series (Feature Requests)
by PeterH 1/17/2020 1:41:48 AM(UTC)
PTZ control via NDI (Feature Requests)
by PeterH 1/17/2020 1:38:56 AM(UTC)
Avonic AV-CM60-IP PTZ camera supported for PTZ control? (Hardware Compatibility)
by Ronald555 7/14/2019 2:02:17 AM(UTC)
Allow Virtual PTZ controls on Virtual Set (Feature Requests)
by christianm 6/18/2019 6:45:46 PM(UTC)
PTZ Control - USB Serial port (Feature Requests)
by videokommando 3/22/2019 8:48:16 PM(UTC)
Native PTZ control of NDI cameras (Feature Requests)
by mjgraves 2/3/2019 5:36:35 AM(UTC)
vMix 21 Help - Update needed - PTZ Controls (General Discussion)
by sinc747 8/15/2018 1:20:25 PM(UTC)
