HWL1223
#1 Posted : Sunday, June 22, 2014 12:10:57 PM(UTC)
HWL1223
1. How do you clear a trigger list, or delete an entry in the trigger list?
2. Can you make a trigger list for each video in an Input List or each video/input in a Playlist?
What want to do is have a saved list of video clips playing (input list or playlist), and when a new clip comes into the rotation, have a bug/overlay super over the video with the "subject".
jip
#2 Posted : Sunday, June 22, 2014 2:56:51 PM(UTC)
jip
Estonia
Also regarding Triggers...
Would it be possible to add trigger option when "overlay in" is finished.
For instance, with vMix Social automatically enabling "Overlay 1" with selected title input, that title input could have a trigger of "Overlay1Out" with 5 second delay.
That would make showing tweets fully automatic, and reduce the need to disable social title overlay after a while.
Thanks for considering!
krassesPferd
#3 Posted : Sunday, June 22, 2014 3:58:52 PM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
Very good idea. I had the problem that the triggers of an overlay-input aren't executed.
This would be a real help for future versions.
Yannick
Similar Topics
Triggers on many inputs (General Discussion)
by CoryL.NFLD 3/19/2026 10:11:50 AM(UTC)
ESC key should close “Select a Function” window in Triggers (Feature Requests)
by SeluZ 3/5/2026 9:52:46 PM(UTC)
Triggers for specific index in List input (Feature Requests)
by orwinetkins 1/24/2026 5:18:04 AM(UTC)
Make OnCountdownRemaining and OnCountdownComplete triggers work with the countdown to time function (Feature Requests)
by guidogast 11/3/2025 6:29:58 PM(UTC)
simplified use of triggers (Feature Requests)
by Murchik 10/28/2025 10:20:05 PM(UTC)
Triggers based off an input being used on a layer in program? (General Discussion)
by knbPixels 3/4/2025 8:12:53 AM(UTC)
Playback Time Triggers for photos input and live sources (Feature Requests)
by nikosman88 11/16/2024 5:45:28 AM(UTC)
Is there an API for triggers? (General Discussion)
by DThompson55 7/26/2024 1:53:26 AM(UTC)
Add “OnZoomCameraOn”/”OnZoomCameraOff” Triggers for Assigned Participant (Feature Requests)
by WaltG12 4/28/2024 4:18:07 PM(UTC)
Setting triggers with scripts (General Discussion)
by MSFTGuruGuy 3/15/2024 11:42:16 PM(UTC)
New triggers - audio on / audio off (Feature Requests)
by spinfold 2/20/2024 5:41:54 AM(UTC)
Triggers management options (Feature Requests)
by kardellivemedia 1/25/2024 1:25:06 PM(UTC)
Faster way to copy/paste triggers (Feature Requests)
by SethLT 1/12/2024 5:26:31 AM(UTC)
Triggers to activate /de-activate key shortcuts (Feature Requests)
by sdonn 1/4/2024 3:14:28 AM(UTC)
“Copy to” options for triggers (Feature Requests)
by mandurphy 12/28/2023 10:10:01 PM(UTC)
Shortcuts for Triggers (Feature Requests)
Belarus Edy Santos 11/21/2023 10:39:47 PM(UTC)
VMix Triggers Part 2 (General Discussion)
by mattford1 11/6/2023 2:23:39 AM(UTC)
VMix Triggers (General Discussion)
by mattford1 11/6/2023 12:27:40 AM(UTC)
Shortcut To Deactivate Triggers (Feature Requests)
by shawntempesta 9/22/2023 6:55:31 AM(UTC)
Add triggers for recording start/stop (Feature Requests)
by fgolman 9/14/2023 3:05:09 PM(UTC)
Google Sheets Triggers (General Discussion)
by Ruben Blammo 9/3/2023 7:00:43 PM(UTC)
BUG report: vMix Triggers being ignored (General Discussion)
by Roy Sinclair 8/1/2023 9:11:12 AM(UTC)
Overlay that shows which triggers are activated (General Discussion)
by AuditorRSTO 7/20/2023 10:32:05 PM(UTC)
Replay Triggers (General Discussion)
by petengokeh 5/28/2023 8:19:59 PM(UTC)
Scoreboard triggers to title indicators from XML (General Discussion)
by MSFTGuruGuy 5/10/2023 4:22:49 AM(UTC)
Add OnPresetLoaded Triggers (Feature Requests)
by gpdipalmerahtimur 1/26/2023 3:53:46 PM(UTC)
Stream Triggers (Feature Requests)
by Guest 11/15/2022 12:14:51 AM(UTC)
any way to toggle triggers programmatically? (General Discussion)
by DThompson55 10/15/2022 5:57:05 AM(UTC)
Shortcuts and Triggers with PTZ Cameras (General Discussion)
by marcuscole 7/29/2022 3:19:32 AM(UTC)
set triggers to start at certain time of day (General Discussion)
by Noel Mustchin 6/21/2022 12:52:37 AM(UTC)
