Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
1. How do you clear a trigger list, or delete an entry in the trigger list? 2. Can you make a trigger list for each video in an Input List or each video/input in a Playlist?
What want to do is have a saved list of video clips playing (input list or playlist), and when a new clip comes into the rotation, have a bug/overlay super over the video with the "subject".
Joined: 7/23/2013(UTC) Posts: 133  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
Also regarding Triggers...
Would it be possible to add trigger option when "overlay in" is finished.
For instance, with vMix Social automatically enabling "Overlay 1" with selected title input, that title input could have a trigger of "Overlay1Out" with 5 second delay.
That would make showing tweets fully automatic, and reduce the need to disable social title overlay after a while.
Thanks for considering!
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
jip wrote: Would it be possible to add trigger option when "overlay in" is finished.
Very good idea. I had the problem that the triggers of an overlay-input aren't executed. This would be a real help for future versions. Regards, Yannick
