SeluZ
#1 Posted : Thursday, March 5, 2026 9:52:46 PM(UTC)
SeluZ
Spain
I noticed a small usability issue while working with Triggers in vMix.
When adding a trigger and opening the "Select a Function" window, if I start typing or browsing functions and then decide I don’t want to use it, my instinct is to press the ESC key to close the window.
Current behavior:
  • Pressing ESC does not close the window
  • Windows plays an error sound
  • The window remains open
  • The only way to close it is by clicking the X button with the mouse
Expected behavior:
  • Pressing ESC should close the "Select a Function" window
  • This should behave the same as pressing cancel or closing the dialog
In most software interfaces, when a modal or pop-up window is active, pressing ESC cancels the action or closes the dialog. This is a very common UI convention.
Allowing ESC to close this window would make trigger editing faster and more intuitive, especially when experimenting with different functions.
Thanks for considering it.
