Feature Requests
ESC key should close “Select a Function” window in Triggers
Rank:: Newbie
Hi, I noticed a small usability issue while working with Triggers in vMix. When adding a trigger and opening the "Select a Function" window, if I start typing or browsing functions and then decide I don’t want to use it, my instinct is to press the ESC key to close the window. Current behavior:
- Pressing ESC does not close the window
- Windows plays an error sound
- The window remains open
- The only way to close it is by clicking the X button with the mouse
Expected behavior:
- Pressing ESC should close the "Select a Function" window
- This should behave the same as pressing cancel or closing the dialog
In most software interfaces, when a modal or pop-up window is active, pressing ESC cancels the action or closes the dialog. This is a very common UI convention. Allowing ESC to close this window would make trigger editing faster and more intuitive, especially when experimenting with different functions. Thanks for considering it.
Feature Requests
