advisiontv
#1 Posted : Monday, May 4, 2020 7:04:24 AM(UTC)
advisiontv
I've just remembered that I have an old JL Cooper ES-4/100 controller lying around my office. It's a MIDI Desktop Automation Controller with 4 faders and buttons (but can shift banks to 8 as it internally remembers the settings). It says it comes with a standard MIDI interface that connects to any device that has a MIDI interface and is USB.
Would this work with vmix to control my first 4 or hopefully 8 inputs??
Ive given up trying to get the motorized faders working on my X-Touch!!!
TrevoorB
#2 Posted : Saturday, May 16, 2020 7:39:56 PM(UTC)
TrevoorB
My home interfaced GVG panel works this way connect it up, go to settings, shortcuts, add, find, and then press a button on your controller. it should take you back to the add menu, and have entered the Key data at the top, so you need to add the function you require that button to perform in the dropdown good luck
Similar Topics
Midi Controller - Donner StarryCtrl (Hardware Compatibility)
by smaney 5/27/2026 3:16:38 PM(UTC)
T-Bar roll replay with MIDI Controller does not work (Instant Replay)
by furtive 8/28/2024 9:42:07 AM(UTC)
Shortcut Select Registered Replay Tags in Midi Controller without mouse and Keyboard (Feature Requests)
by WesleyFernandes 8/6/2021 12:17:51 AM(UTC)
Shortcut Instant Replay Select events with midi controller without mouse and keyboard (Feature Requests)
by WesleyFernandes 8/6/2021 12:13:29 AM(UTC)
Suport for sub zero midi controller (Feature Requests)
by stefan svanstrom 7/30/2021 11:10:19 AM(UTC)
affecting virtual sets in preview..changing inputs via a midi controller (General Discussion)
by durtball 7/29/2021 12:24:33 AM(UTC)
Doubt, midi controller button as switch, not as push button (General Discussion)
by Xavi137 6/12/2021 6:37:28 AM(UTC)
Recommendations for shortcuts on a Midi Controller (General Discussion)
by clibil 12/9/2020 9:07:10 PM(UTC)
MIDI controller Audio Mixer VMiX (General Discussion)
by pratyekmeal6 8/4/2020 3:40:14 AM(UTC)
Will this midi controller work to activate vmix shortcuts? (Hardware Compatibility)
by Osprey 4/24/2020 9:34:14 PM(UTC)
Jittery Transitions with MIDI Controller (General Discussion)
by AgentPete 6/16/2019 7:29:49 AM(UTC)
Midi Controller for 2 Vmix PC (General Discussion)
by macgiver76 5/21/2019 4:11:43 AM(UTC)
Simple MIDI Controller with LEDs (3rd Party Software and Development)
by VQey 1/4/2019 12:47:28 PM(UTC)
Midi Controller Fader inverting? (General Discussion)
by GTiDon 8/28/2018 1:38:27 PM(UTC)
rtpMIDI use a signle USB MIDI controller with multiple vMix machines (General Discussion)
by smudge1977 8/14/2018 5:04:02 PM(UTC)
How to use 2x Akai Professional APC Mini midi controllers (Hardware Compatibility)
by kevev 8/2/2018 3:08:35 PM(UTC)
Multiple MIDI controllers support (Hardware Compatibility)
by TeosVerdi 7/14/2018 9:50:12 AM(UTC)
vMix optimized Midi Controller (General Discussion)
by Yannick 7/4/2018 7:23:07 AM(UTC)
2 MIDI Controllers? (Hardware Compatibility)
by spencerm24 5/30/2018 2:49:07 PM(UTC)
Midi controller over KVM ethernet extender not working (General Discussion)
by spencerm24 4/22/2018 12:59:43 PM(UTC)
Toggle Shortcuts on some MIDI Controllers (General Discussion)
by Argo82 2/14/2018 12:33:21 PM(UTC)
2 midi controllers on 1 vmix (Hardware Compatibility)
by cruiseweekTV 1/4/2018 8:12:48 PM(UTC)
MIDI controller stopped working in the middle of a stream... (General Discussion)
by seb666 11/15/2017 4:13:26 AM(UTC)
More than 1 Midi controller on vMix? (Hardware Compatibility)
by digitalalps 8/25/2017 4:27:50 AM(UTC)
Midi Controller for Camera Audio (General Discussion)
by imagebotique 5/10/2017 6:09:34 PM(UTC)
Midi Controller Unplugged (General Discussion)
by TrentisN 4/11/2017 2:22:38 AM(UTC)
DVE with midi controller (General Discussion)
by mrjoe 4/4/2017 3:48:10 PM(UTC)
Possible to implement own Activator for MIDI Controller? (Hardware Compatibility)
by seb666 3/22/2017 8:03:41 AM(UTC)
DIY MIDI Controller (General Discussion)
by bino 1/15/2017 6:48:44 AM(UTC)
Midi controller opinion (my xmas ;-) ) (Hardware Compatibility)
by doggy 12/15/2016 3:44:49 PM(UTC)
