advisiontv
#1 Posted : 5 years ago
advisiontv
I've just remembered that I have an old JL Cooper ES-4/100 controller lying around my office. It's a MIDI Desktop Automation Controller with 4 faders and buttons (but can shift banks to 8 as it internally remembers the settings). It says it comes with a standard MIDI interface that connects to any device that has a MIDI interface and is USB.
Would this work with vmix to control my first 4 or hopefully 8 inputs??
Ive given up trying to get the motorized faders working on my X-Touch!!!
TrevoorB
#2 Posted : 5 years ago
TrevoorB
My home interfaced GVG panel works this way connect it up, go to settings, shortcuts, add, find, and then press a button on your controller. it should take you back to the add menu, and have entered the Key data at the top, so you need to add the function you require that button to perform in the dropdown good luck
Similar Topics
T-Bar roll replay with MIDI Controller does not work (Instant Replay)
by furtive 8 months ago
Shortcut Select Registered Replay Tags in Midi Controller without mouse and Keyboard (Feature Requests)
by WesleyFernandes 4 years ago
Shortcut Instant Replay Select events with midi controller without mouse and keyboard (Feature Requests)
Suport for sub zero midi controller (Feature Requests)
by stefan svanstrom 4 years ago
affecting virtual sets in preview..changing inputs via a midi controller (General Discussion)
by durtball 4 years ago
Doubt, midi controller button as switch, not as push button (General Discussion)
by Xavi137 4 years ago
Recommendations for shortcuts on a Midi Controller (General Discussion)
by clibil 4 years ago
MIDI controller Audio Mixer VMiX (General Discussion)
by pratyekmeal6 5 years ago
Will this midi controller work to activate vmix shortcuts? (Hardware Compatibility)
by Osprey 5 years ago
Jittery Transitions with MIDI Controller (General Discussion)
by AgentPete 6 years ago
Midi Controller for 2 Vmix PC (General Discussion)
by macgiver76 6 years ago
Simple MIDI Controller with LEDs (3rd Party Software and Development)
by VQey 6 years ago
Midi Controller Fader inverting? (General Discussion)
by GTiDon 7 years ago
rtpMIDI use a signle USB MIDI controller with multiple vMix machines (General Discussion)
by smudge1977 7 years ago
How to use 2x Akai Professional APC Mini midi controllers (Hardware Compatibility)
by kevev 7 years ago
Multiple MIDI controllers support (Hardware Compatibility)
by TeosVerdi 7 years ago
vMix optimized Midi Controller (General Discussion)
by Yannick 7 years ago
2 MIDI Controllers? (Hardware Compatibility)
by spencerm24 7 years ago
Midi controller over KVM ethernet extender not working (General Discussion)
Toggle Shortcuts on some MIDI Controllers (General Discussion)
by Argo82 7 years ago
2 midi controllers on 1 vmix (Hardware Compatibility)
by cruiseweekTV 7 years ago
MIDI controller stopped working in the middle of a stream... (General Discussion)
by seb666 7 years ago
More than 1 Midi controller on vMix? (Hardware Compatibility)
by digitalalps 8 years ago
Midi Controller for Camera Audio (General Discussion)
by imagebotique 8 years ago
Midi Controller Unplugged (General Discussion)
by TrentisN 8 years ago
DVE with midi controller (General Discussion)
by mrjoe 8 years ago
Possible to implement own Activator for MIDI Controller? (Hardware Compatibility)
by seb666 8 years ago
DIY MIDI Controller (General Discussion)
by bino 8 years ago
Midi controller opinion (my xmas ;-) ) (Hardware Compatibility)
by doggy 8 years ago
AdjustCountdown with MIDI controller (General Discussion)
by calamityjane 8 years ago
