Was thanked: 3 time(s) in 1 post(s)
I am trying to use 2 midi controllers on the same vmix system.
I have either 1 or 2 apc mini's or 1 apc mini and 1 novation launchpad mini
here is what i have found with the apc and the novation connected but switched to midi channel 4
1: I can change the channel on the novation. HOWEVER it still reports on the find button as channel 1 EVEN though it works so it's just a reporting bug i think. so for the ability to have this and an apc mini on the same vmix. 2: the lights on the buttons. this wont work, it seems to, at least for the lights both light the same key on each pad at the same time.
anyone got this working fully?
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
using midi-ox remap funtion we uses 2 akai apc mini and 1 akai midimix in the same computer incluided the activator.
dark_ata wrote:using midi-ox remap funtion we uses 2 akai apc mini and 1 akai midimix in the same computer incluided the activator. oh great, looking at that now. is there an easy way to just map everything comeing in on channel 1 on one unit to channel 2 or do i have to map each key separately ?
