waldron18
#1 Posted : Friday, June 28, 2019 8:59:08 AM(UTC)
waldron18
Just wondering if people could recommend a decent size audio interface you have not had any issues with in vMix?
I've tried a Focusrite 18i20 and a Focusrite 6i6 and both give me some "ticking" audio every now and then which is not good. I have increased the buffer to the maximum 20ms of the devices and still no improvement.
Any help to fix it, or suggestions on a different device would be appreciated.
Thanks!
richardgatarski
#2 Posted : Friday, June 28, 2019 5:12:37 PM(UTC)
richardgatarski
my guess is that you have mixed sample rates in the chain. vMix's default is 48 kHz, check all audio playback and recording devices in Window's Cotrol panel/Sound
sinc747
#3 Posted : Tuesday, July 2, 2019 7:46:52 AM(UTC)
sinc747
But ticking in audio can be a symptom of a hardware issue as well. I had ticking in my audio for a few months, then the motherboard died. New motherboard... no ticking.
I like the Behringer UMC404HD as an audio interface. It is the one that Martin & Tim use for their monthly vMic Fun Time Live shows. It is USB-powered and all four of the Behringer's audio sources can be added into vMix as separate audio inputs using the ASIO drivers supplied with the Behringer.
- Tom
waldron18
#4 Posted : Monday, August 12, 2019 8:23:22 PM(UTC)
waldron18
So I've been tweaking things and I'm still getting the issue. It seems to be made worse when I'm recording. I have made sure everything is set to 48khz sample rate (focusrite, vmix and windows). However in vmix recording you can't select 48khz... any idea why? Could this be causing an issue?
Any other thoughts what it could be?
Cheers
Similar Topics
USB audio interface (Hardware Compatibility)
by Bodo 3/24/2026 7:51:32 PM(UTC)
Recommend No audio dropouts audio interface (Hardware Compatibility)
by yoonminsoo 7/13/2025 7:33:03 PM(UTC)
audio interface or sound mixing console, with XLR inputs, that VMIX independently recognizes each of (Hardware Compatibility)
by jaialai 5/10/2024 4:49:18 AM(UTC)
Multiple Audio interfaces - UMC1820 - UMC404HD (Hardware Compatibility)
by adrider 12/5/2023 8:54:49 PM(UTC)
vMix 27 audio interface and settings issues (Beta Discussion)
by WatsonPrunier 11/2/2023 2:06:19 AM(UTC)
vMix & DAW, Same PC, 2 Audio Interfaces? (General Discussion)
by JB2022 11/4/2022 12:25:52 AM(UTC)
Improve USB audio interface persistence (Feature Requests)
by TBacker 10/14/2022 5:40:24 AM(UTC)
audio interface buffer size (General Discussion)
by steelman20 10/7/2022 5:03:25 AM(UTC)
Bus A, B, C to USB Audio Interface (General Discussion)
by allklier 5/6/2022 10:03:57 PM(UTC)
Recommend me an Audio Interface? (General Discussion)
by dcoplin 1/18/2022 6:23:01 AM(UTC)
How can I turn my audio interface into my amp? (Hardware Compatibility)
by taylor10 5/5/2021 11:41:05 PM(UTC)
audio: listening from headphones through audio interface (General Discussion)
by chef Shannon 5/1/2021 12:34:08 PM(UTC)
8 Channel Audio Interface (Hardware Compatibility)
by jeremyl 5/1/2021 5:43:12 AM(UTC)
Audient EVO 4 - USB audio interface (Hardware Compatibility)
by Monday Production 4/30/2021 2:46:58 AM(UTC)
Wrong inputs displayed for audio interface (Hardware Compatibility)
by boburtz 3/16/2021 9:30:34 AM(UTC)
AUDIO INTERFACE for a TV show (Hardware Compatibility)
by davidcl 12/13/2020 9:30:05 PM(UTC)
USB audio interfaces with mix/minus capability (Hardware Compatibility)
by huggybear 11/29/2020 2:23:06 PM(UTC)
Tascam US-16x08 USB Audio Interface (Hardware Compatibility)
by DwFMagik 7/16/2020 8:41:27 AM(UTC)
Stability: Focusrite vs Presonus (SCARLETT 18I20 GEN-3 vs Studio 1824c Audio Interface) (Hardware Compatibility)
by onesimus 7/10/2020 3:52:53 AM(UTC)
Mixing Deck / Audio Interface Suggestions (Hardware Compatibility)
by hidavid 6/2/2020 10:19:53 PM(UTC)
Behringer X1204USB Audio interface / Mixer (3rd Party Software and Development)
by thargrove 3/24/2018 2:12:50 PM(UTC)
Browser support for audio interfaces with vMix Call (vMix Call)
by noneric 1/31/2018 7:13:21 AM(UTC)
2 USB audio interfaces? (Hardware Compatibility)
by spencerm24 9/23/2017 2:45:12 PM(UTC)
Problems Adding Audio Input (line in, Audio Interface) (Hardware Compatibility)
by PVP 3/28/2015 6:35:57 PM(UTC)
Audio interface.. and compression limiter function (Feature Requests)
by isaia 7/23/2013 5:41:44 AM(UTC)
