xaver
#1 Posted : Monday, July 3, 2017 3:56:34 PM(UTC)
xaver
I try to get a negativ audio delay in a RTSP stream
it's not working
a positiv audio delay works, but my stream needs a video delay
how can I solve this?
mjgraves
#2 Posted : Tuesday, July 4, 2017 12:27:58 PM(UTC)
mjgraves
Despite centuries of effort, travel back in time is still not possible ;-)
A stream arrives (v+a) an audio "delay" will retard that presentation of the audio relative to the video.
A negative audio delay is not possible.
A video delay would retard the presentation of the video relative to the audio. Not exactly sure if/how that might be done in vMix.
As has been mentioned elsewhere hereabouts, many times, RTSP/RTMP are not really suitable for production purposes. Most especially when you have concerns about latency. Which is sounds like you have.
xaver
#3 Posted : Wednesday, July 5, 2017 4:12:11 PM(UTC)
xaver
but why can I setup a negative audio delay (-1000 msec is possible) if it's not working?
positive delay (tried up to 5 sec) works very well in that RTSP Stream
mjgraves
#4 Posted : Wednesday, July 5, 2017 7:18:59 PM(UTC)
mjgraves
I would suggest that's a quirk in the user interface. You can't do anything to a signal that hasn't arrived yet.
A negative delay is not possible without time travel.
xaver
#5 Posted : Thursday, July 6, 2017 3:09:43 PM(UTC)
xaver
is there any chance to get a video delay?
mjgraves
#6 Posted : Friday, July 7, 2017 8:19:38 AM(UTC)
mjgraves
The following thread describes adjusting a network buffer in order to achieve a long delay of an output stream.
https://forums.vmix.com/...aspx?g=posts&t=11251
I'm not sure if or how you could delay an input stream.
I'm always trying eliminate latency. I've noticed that some video processing, like layering, scaling, etc. can add a little delay. Sometimes as much as a few frames.
For example, I can set a webcam (Logitech Brio) for 4K but bring it into a vMix project running at 720p30. The webcam stream will be delayed by the requirement to scale it down.
mjgraves
#7 Posted : Friday, July 7, 2017 11:44:46 AM(UTC)
mjgraves
I see that in the source settings, in the Advanced menu, there's an option for "Delay." It's enabled for a webcam, but not for an RTMP/RTSP stream.
When used with a webcam, I can enter a delay value (in frames) and the software automatically creates a suitable buffer to achieve the desired delay.
Perhaps in future this mechanism can be extended to allow delay of an incoming stream.
Similar Topics
Audio Delay Change with Update (General Discussion)
by Howard6001 2/10/2024 4:23:26 AM(UTC)
Audio delay settings (General Discussion)
by grimlee 1/23/2022 10:24:23 PM(UTC)
Audio Delay on SDI with embedded Audio (General Discussion)
Belarus udo.schneider 11/1/2021 11:02:18 PM(UTC)
Ability to change audio delay via triggers (Feature Requests)
by MZBC 4/28/2021 10:27:07 AM(UTC)
vMix internal audio delay (General Discussion)
by Adl 3/30/2021 4:37:43 AM(UTC)
Audio Delay on interlaced projects (General Discussion)
by mundm 2/22/2021 6:30:08 PM(UTC)
Audio Delay Capability (General Discussion)
by Rob009 2/2/2021 12:16:55 PM(UTC)
Audio Delay between live and sound on speakers (General Discussion)
by PhoenixDigital 1/20/2021 8:42:43 AM(UTC)
Audio delay off on audio inputs or camera inputs (Feature Requests)
by robbienet 12/7/2020 6:43:26 AM(UTC)
Independent Audio Delay Across Multiple Streams (General Discussion)
by jermanprod 8/26/2020 3:38:45 AM(UTC)
API/Shortcut addition - fader control of input audio delay - SetAudioDelay (Feature Requests)
by jsandytn 8/17/2020 10:12:03 PM(UTC)
Audio delay compensation for plugins (General Discussion)
by soham 8/7/2020 4:18:53 AM(UTC)
Audio Delay in My Headphones (General Discussion)
by mppfeffer 6/18/2020 6:48:12 AM(UTC)
Audio delay API control (Feature Requests)
by Jp12687 6/17/2020 9:51:49 AM(UTC)
Recording audio delay issue (General Discussion)
by hmastet 6/9/2020 11:12:21 PM(UTC)
Add API/shortcut to set audio delay (Feature Requests)
by Booth 6/3/2020 6:46:36 PM(UTC)
Record audio delay not working (General Discussion)
by PosLanNik 5/30/2020 2:39:10 AM(UTC)
Audio Delays for Outputs/Busses (Feature Requests)
by dperaltajr 5/18/2020 2:31:21 AM(UTC)
audio delay control through API? (3rd Party Software and Development)
by jimboy 5/16/2020 8:21:02 PM(UTC)
Going nuts with audio delay! (General Discussion)
by stevethornley 3/30/2020 5:20:47 AM(UTC)
Audio delay does not have any effect (General Discussion)
by radamo 3/28/2020 8:11:19 PM(UTC)
Audio delay/echo problem (General Discussion)
by phab 3/27/2020 10:19:25 PM(UTC)
Atem Mini - Audio delay (General Discussion)
by irishmike 1/21/2020 9:36:31 AM(UTC)
Getting the audio delay just right (General Discussion)
by MikkelWinther 9/13/2018 5:27:19 AM(UTC)
Audio delay on videos played in vMix (General Discussion)
by MikkelWinther 9/7/2018 6:42:06 AM(UTC)
Audio delay on microphone input (General Discussion)
by michaelrb 8/30/2018 10:22:11 AM(UTC)
vMix and Skype - Audio delay (General Discussion)
by antonis.zoumpakis 2/23/2018 8:18:45 AM(UTC)
Audio delay not working (General Discussion)
by Sheriton 10/31/2017 9:27:47 AM(UTC)
audio delay howto? (General Discussion)
by art23 7/25/2017 12:34:47 AM(UTC)
Audio Delay on the Master Audio Output. (General Discussion)
by BETech 6/13/2016 4:22:34 AM(UTC)
