jimboy
#1 Posted : Saturday, May 16, 2020 8:21:02 PM(UTC)
jimboy
I am a newer user to vmix and very pleased with its abilities thus far. I am working on a potential solution for a client need that would require very slight adjustments to the amount of delay on an audio channel (+/- 60ms at any time) and wondering if any of the available API protocols support this. I would be using an external piece of software to determine the change necessary but also requires input data from vmix to give values from a stream RTT delay during a stream (SRT) that can be calculated and used to alter audio delay to a given audio input back in vmix. I understand that there is a little audio artifacting when altering the delay live but that is acceptable for this use case.
While I am familiar with some basics in coding and using API's I wanted to ask if there was already anyone experienced with this (audio input changes) using vmix API's or if I am in new territory here and need to forge ahead on my own or if this is not possible with current API's.
Thank you,
stigaard
#2 Posted : Saturday, May 16, 2020 9:42:11 PM(UTC)
stigaard
Denmark
+1
mkohler
#3 Posted : Friday, May 29, 2020 5:12:05 AM(UTC)
mkohler
+1
jsandytn
#4 Posted : Sunday, September 13, 2020 12:09:25 AM(UTC)
jsandytn
+1
