There only 4 for Multi view how to extend this ?
Perhaps you can explain what it is that you are trying to do... There may be a simple solution that is not plainly obvious in vMix, or perhaps it is just not possible or practical with vMix. Either way, in order to help, more information is required as to why you want to "extend" the overlays. If you want or need more overlay channels in addition to what has been described in another thread started by you, then I would suggest making a feature request.
IceStream wrote:Perhaps you can explain what it is that you are trying to do... There may be a simple solution that is not plainly obvious in vMix, or perhaps it is just not possible or practical with vMix. Either way, in order to help, more information is required as to why you want to "extend" the overlays. If you want or need more overlay channels in addition to what has been described in another thread started by you, then I would suggest making a feature request.
Ice okay thank you i will request there
