rowby
#1 Posted : Tuesday, February 20, 2018 10:09:24 PM(UTC)
rowby
Hello Everyone,
From another post I just now discovered that Unckecking an input in the input’s Multi View tab does not disable the input. It only disables the visibility of the selected input. For example if the input has audio the audio will still play if the input is not checked.
Therefore, instead if a checkbox, I recommend changing to it an eyeball. Eyeball on = visible. Eyeball off = not visible. By default Eyeball would be ON.
Rowby
